Sorry, this one fell below the bottom of the page.
The error you're getting is unusual because the value in question is defined in the Adafruit_VS1053 library. The only thing I can think of would be a garbled download.
Try deleting that library and reinstalling a fresh copy from Github.
Help Combining Music Maker Code 1790 - No Amp with Class D M
- Larry67
Re: Help Combining Music Maker Code 1790 - No Amp with Class
Mike
I want to close the loop on this topic. I was able to maintain maximum volume using the following code. Hope this is helpful to anyone trying to do something similar.
What I ended up doing is taking the Player Simple example and modifying the code, connecting my 9744 amplifier for digital control (even though I am not adjusting the volume for digital control) and I added a motion sensor to play a song when motion is detected. My code and the breakout boards now work independent of the computer using 9 volt power supplies. But with one caveat. I have to maintain voltage on the boards why moving them into their desired position. Not perfect, but at least I don't need the boards connected to my laptop perpetually. Fortunately I live in a location where a power outage may occur once every two years.
I set the volume to maximum in the player simple code - Volume at 1 instead of 20 that is supplied with the example. So now there is no reason for me to try and run two amplifiers in series as I posted in another question. Here is my code for anyone wanting to do something similar.
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
#define BREAKOUT_RESET 9 // VS1053 reset pin (output)
#define BREAKOUT_CS 10 // VS1053 chip select pin (output)
#define BREAKOUT_DCS 8 // VS1053 Data/command select pin (output)
#define SHIELD_RESET -1 // VS1053 reset pin (unused!)
#define SHIELD_CS 7 // VS1053 chip select pin (output)
#define SHIELD_DCS 6 // VS1053 Data/command select pin (output)
#define CARDCS 4 // Card chip select pin
#define DREQ 3 // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer =
Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
int counter = 0;
int pirSensorPin = 2;
int val = 0;
int calibrationTime = 1;
pinMode(pirSensorPin, INPUT);
Serial.begin(9600);
Serial.println("Waiting for the sensor to warm up.");
delay(calibrationTime * 1000); // Convert the time from seconds to milliseconds.
Serial.println("SENSOR ACTIVE");
Serial.println("Adafruit VS1053 Simple Test");
musicPlayer.begin();
SD.begin(CARDCS);
// Set volume for left, right channels. lower numbers == louder volume!
musicPlayer.setVolume(1, 1);
musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT); // DREQ int
Serial.println(F("Playing track 001"));
musicPlayer.playFullFile("track001.mp3");
val = digitalRead(pirSensorPin); // read input value
if (val == HIGH) { // check if the input is HIGH
while (counter < 3) {
delay (100);
counter ++;
Serial.println(counter);
counter = 0;
delay(1000);
Last edited by adafruit_support_mike on Tue Sep 04, 2018 3:54 am, edited 1 time in total.
Reason: fixed CODE tags
Glad to hear you got things working in a way you can accept. Happy hacking!
