I have the same problem as the rest of the people on this: viewtopic.php?f=8&t=137983&p=682907&hil ... ot#p682907
Order: 1825402-1354602471
Raspberry Pi 3 - Model B+ - 1.4GHz Cortex-A53 with 1GB RAMPID: 3775
Power lite LED comes on but no activity. The card works in other Pi3s...
Brand new Raspberry Pi 3 - Model B+ - 1.4GHz Cortex-A53 with
- naderrahimizad
- 39129664_685281095157356_7654555384253775872_n.jpg (89.52 KiB) Viewed 130 times
- 39177646_642676466119153_4911465282465169408_n.jpg (121.23 KiB) Viewed 130 times
- Franklin97355
Re: Brand new Raspberry Pi 3 - Model B+ - 1.4GHz Cortex-A53
Are the others Pi3 B+'s? what do you get when you measure the voltages on the power pins (5 and 3.3 volts)?
- naderrahimizad
pin 2= 5.078
pin 4 = 5.078
pin 1 = 0.007
pin 4 = 5.078
pin 1 = 0.007
- naderrahimizad
shouldnt pin 1 be 3.x vdc?
- Franklin97355
Send a note containing a link to this page and your order number to [email protected]. They will get you a replacement and will arrange return shipping for the one you have now.
- naderrahimizad
Thank you. I did order the replacement today.
By the way my 2nd order arrived today: 1829969-9301616801
On this one, the 3B+ shows under voltage detected on 5vdc 1.8a, 2.5a, and 3a charger units. so no matter how large it is, it still shows under voltage. is this problem related to the unit that i just got an RMA for or is this a new problem?
- naderrahimizad
It the Servo hat has the 5V power purchased from AdaFruit but even without the HAT on, the same error is displayed: under voltage detected
- 39441856_1804950769542837_7884492114917064704_n.jpg (82.72 KiB) Viewed 84 times
