Hey Everyone,
I read most of the posts on the Zelda guardian sword, but couldn't find what I am having an issue with. I have everything wired exactly like the diagram provided and I used CircuitPython code to my Trinket M0.
The LEDs work AMAZING and are all the correct colors. My issue though, is when I plug the battery in the Lipo Backpack, the LEDs light up regardless if the slide switch is on or off.
My plan is to re-solder the slide switch again, but does anyone have any idea (besides maybe bad soldering) why this might be happening? Ill update my post if the re-soldering does or doesn't work.
Thank you for your time.
Breath of the Wild Sword
- thebrendini
Re: Breath of the Wild Sword
No luck for me. I soldered and soldered and can not get the slide switch to work. I had spare toggle switches that I also tried and same thing. Once the battery is plugged in I can’t toggle on or off it just stays on. Please help me! Lol
- Attachments
- 8B86DC1C-DC7F-41C3-8B90-682322BB1E33.jpeg (451.53 KiB) Viewed 91 times
- 5C11F8E6-ACCC-414D-B904-7B3FCE22BBC6.jpeg (485.18 KiB) Viewed 91 times
- A1BB34E9-A2B2-4007-9339-2392B297091A.jpeg (424.46 KiB) Viewed 91 times
- thebrendini
Here are a few more pictures
- Attachments
- 2F625F35-12A7-4D1D-8D2E-6F52D5677D39.jpeg (302.67 KiB) Viewed 91 times
- AE23C05C-14C8-4B7E-B5A4-A7EC5FFAD182.jpeg (658.16 KiB) Viewed 91 times
It looks like you need to use some flux on the joints at the PCB. I see a lot of exposed gold there, which often means the solder isn't making a good connection to the pad.
Take a look at our soldering tutorial, give each joint a dab of flux, and reheat them. You want a smooth, shiny cone that covers the pad and sweeps up to the pin:
https://learn.adafruit.com/adafruit-gui ... -soldering
- thebrendini
Thank you for the advice! I will try it out!
