I have a PowerBoost1000 connected via the micro USB Socket from a 2A wall adapter. It gets very hot as mentioned in the FAQ. When I connect a LiIon-cell to the connector, it seems to load since the current from the wall adapter increases. But there is no output power. A connected 6V-bulb does nothing, a red LED with 2k resistor blinks with about 2 Hz. Connecting the EN to 5V has no effect.
Is there a minimal load for the device?
PowerBoost 1000 with no output
Re: PowerBoost 1000 with no output
The PowerBoost doesn't have a required minimum load, but the components shouldn't heat up without a load.
Post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
- heimi
Hi
I received a second PowerBoost that works as expected: foto PowerBoost_OK. The connected Raspi works well, blue LED is on, device is no hotspot.
Fotos in the zip file
The first PoerBoost si not working: foto PowerBoost_fail. After the failed testing I soldered headers to connect a switch for the enable input with no success. There are no shortcuts. Potential at EN is about 1.2V. Blue LED never went on. LED near chrg is on, device is hot.
- Attachments
- PowerBoost.jpg (139 KiB) Viewed 98 times
- PowerBoost_OK.jpg (146.24 KiB) Viewed 98 times
You don't have a battery connected to the PowerBoost.
The PowerBoost 1000C requires a LiPo. If you try to power a load without one, it can damage the MCP73871 load-sharing LiPo charger.
