Pi zero defective?
- K1ll1n355
Re: Pi zero defective?
I checked it out on a PC minus and sd card and it popped up like normal. So i installed raspbian lite again and the error showed up immediately.
- 20181119_143952.jpg (491.58 KiB) Viewed 126 times
- adafruit_support_carter
So it passed that sanity check. But doesn't boot.
Could it be power related? What are you using for a power supply and cable?
- K1ll1n355
I'm using the same power cable assured to work on the pi zero 1.3 on the pi zero w. After uninstalling and reinstalling rapsbian lite I'm attaching photos of 3 different boots on the pi zero w and finally using the same exact set up with a successful boot (same install on the same sd card and same power supply) on the pi zero 1.3.
- 20181120_125000.jpg (771.51 KiB) Viewed 111 times
- 20181120_124809.jpg (353.7 KiB) Viewed 111 times
- 20181120_124756.jpg (621.07 KiB) Viewed 111 times
- K1ll1n355
This is the successful boot on the pi zero 1.3 again with the same install, same sd card, and same power supply.
- 20181120_125324.jpg (629.87 KiB) Viewed 111 times
- K1ll1n355
Just tried to see if n00bs would do anything different and again only worked on the pi zero 1.3.
Thanks for all the troubleshooting attempts.
Not sure what it is. Let's just go ahead and try a replacement. Send an email to [email protected] with a link to this thread and your order number and they can get you a replacement Pi Zero W.
- K1ll1n355
Thank you. Email sent
@colestock Please start a new thread for your issue.
