wifi/BT/RF motion sensor to activate recirculation pump for
by Father_of_Ash on Wed Jan 30, 2019 9:33 pm
Hello All.
I recently discovered this site in the process of researching how I can wireless activate a re-circulation pump on my water heater and I found the M4 RF transmitter relay which I thought was nice. but then realized a motion sensor would be the perfect solution.
I'm hoping someone can help me find the most efficient configuration for a motion sensor to wireless/Bluetooth/Radio-frequency activate a momentary relay connected to the water heater. the water heater does have an option for a wired momentary push button.
Any-ones help would be much appreciated.
Bilal
Father_of_Ash
Re: wifi/BT/RF motion sensor to activate recirculation pump
by franklin97355 on Thu Jan 31, 2019 1:01 am
Let's start out with an explanation of what sequence of events and triggers you want to achieve.
franklin97355
by Father_of_Ash on Thu Jan 31, 2019 1:36 am
Hi, thank you for the reply.
I walk into the bathroom and some type of motion or proximity sensor activates and sends signal to a momentary relay at the heater. I would also like to add 2 wireless push buttons to activate the relay the same way, unless it will over complicate this system.
please let me know if there are any other details you need.
Father_of_Ash
by franklin97355 on Thu Jan 31, 2019 2:06 am
How far from the bathroom to the heater button and where are the two remote switches to be located in relation to this?
franklin97355
by Father_of_Ash on Thu Jan 31, 2019 2:31 am
Bathrooms are on second floor max 30ft. Heater is in basement.
wireless push buttons would be relatively close. one about 10-15ft. away. the other on 1st floor roughly 15ft. away.
Father_of_Ash
by Father_of_Ash on Tue Feb 12, 2019 11:24 am
Hello
Would it be possible to wire an IR beam sensor into one of your single push button 315mhz RF remotes? Once the beam is broken it will act as if the button was pushed? part #s 1392 & 2167. And use the Simple RF M4 Receiver part# 1096.
Would it be as simple as wiring the signal and negative wires to the remote push button and feed it 5v?
Thank you.
Father_of_Ash
by franklin97355 on Tue Feb 12, 2019 2:20 pm
A transistor may be needed to create the short but it is doable.
franklin97355
by Father_of_Ash on Wed Feb 20, 2019 10:26 am
Thank you for the response.
I guess I didn't read the description the first time... The IR beam is only good for 10"-20" and requires reflector.
I think the PIR sensor ID#189 will work much better. would i need a 10k resistor for this as well? and do you offer tiny power supplies for this? or will it run off battery for a decent amount of time?
Father_of_Ash
