Adafruit SHARP Memory Display Breakout - 1.3" 168x144
by lightcast on Mon Feb 11, 2019 12:12 pm
I purchased two Adafruit SHARP Memory Display Breakout - 1.3" 168x144 and I can't get anything to display on the screens. I just see a bunch of dots. I'm using a brand new soldering iron and I soldered the header pins on each of the display boards. I'm using the sample code provided and I still can't get anything to display.
After I couldn't get it working I solder the header pins on two 0.96 OLED display boards. I tested those and it worked perfectly. I mention this because I don't think it's my soldering work.
Any suggestions?
lightcast
Re: Adafruit SHARP Memory Display Breakout - 1.3" 168x144
by adafruit_support_bill on Mon Feb 11, 2019 12:57 pm
Please post some photos showing your soldering and connections and we'll take a look.
by lightcast on Mon Feb 11, 2019 7:40 pm
I've posted a pic. Do you want me to post a pic of both of the screens? I posted one.
lightcast
by adafruit_support_bill on Mon Feb 11, 2019 8:17 pm
The connections all look correct. Try re-wiring in a different area of the breadboard with a different set of jumpers. Breadboard connections are notoriously flaky. And we occasionally see a bad jumper too.
by lightcast on Mon Feb 11, 2019 8:46 pm
So I tried a new breadboard and brand new wires and also another Arduino. Same thing. Do you think that I somehow shorted it out?
lightcast
by adafruit_support_bill on Mon Feb 11, 2019 9:09 pm
Do you get the same pattern every time on both displays? Or is it completely random?
by lightcast on Mon Feb 11, 2019 9:15 pm
I've attached a picture of what i get.
Thanks a bunch for your help BTW.
lightcast
by adafruit_support_bill on Tue Feb 12, 2019 6:45 am
OK. So looks like both are displaying the same thing. Does that pattern change at all as the "sharpmemtest.ino" example is running?
by lightcast on Tue Feb 12, 2019 6:56 am
No. It's the same for both. I'm using an UNO R3 if that makes any difference. The same pattern gets displayed as soon as I connect my UNO to my Mac. When I unplug it it goes away. So the same thing happened when I purchased this display from Amazon a month ago. I first thought that it was something with my soldering and I shorted it out. So I purchased two more directly from Adafruit. So I now have three boards that are doing the same thing :(
lightcast
by adafruit_support_bill on Tue Feb 12, 2019 7:13 am
But is your UNO running the "sharpmemtest.ino" example code?
by lightcast on Tue Feb 12, 2019 7:18 am
Yes. I uploaded the sketch to both of my UNOs and the same thing happens for both. Should I post the code here?
lightcast
I'm running the example sketch.
lightcast
by adafruit_support_bill on Tue Feb 12, 2019 7:36 am
I'll check with manufacturing to see if anything changed on these displays. Since all 3 are acting the same, it doesn't sound like a damaged display.
by adafruit_support_bill on Tue Feb 12, 2019 2:59 pm
Something did indeed change! The current generation display is significantly higher resolution than the original (144x168 vs 96x96). Since it requires a frame buffer in RAM, there is not enough memory in an UNO to drive them. (See the comment at the top of the example code file: https://github.com/adafruit/Adafruit_SH ... st.ino#L29 )
You would need a processor with more RAM like a Metro M0 : https://www.adafruit.com/product/3505
by lightcast on Tue Feb 12, 2019 3:23 pm
Thanks for the reply. I was going crazy. I guess I should've read the code. It says on line 30: it WILL NOT WORK on Arduino Uno. LOL
Thanks a bunch for your help!
lightcast
