help please new thanks for help
by angelstar on Tue Feb 12, 2019 1:09 pm
hello sorry for my english i m french
the product flora 2 if i put more 10 product it will give problem power?
if i put flora 2 sewn textile and i put it on washing machine, the flora 2 are not impermeable
will be distroy? all the product flora neopixel are not impermeable, can be in the washing machine?
thanks for help
angelstar
Re: help please new thanks for help
by adafruit_support_bill on Tue Feb 12, 2019 1:45 pm
I'm sorry. I don't understand the question. Can you explain in more detail?
If you disconnect all batteries and other power sources, you can hand-wash or gently machine wash the Flora. But please allow everything to dry completely before re-connecting power to the circuit:
https://learn.adafruit.com/washing-wear ... s/overview
by angelstar on Wed Feb 27, 2019 1:42 pm
thanks for answer
if i put in serie flora, i do not have to put more than 10 in serie
even if there is problem with power alimentation?
need more power ?
can work with DC 5volt 10 A 50 watt?
thanks jean
angelstar
by adafruit_support_bill on Wed Feb 27, 2019 3:12 pm
need more power ?
Are you referring to the Flora Neopixels? : https://www.adafruit.com/product/1260
The power for these is wired in parallel. You need about 60mA per pixel for maximum brightness. So for 10 pixels you would need 5v @ 0.6A.
by angelstar on Thu Feb 28, 2019 4:54 am
thanks for help
just to know please with flora 2
if i put 10 or more product the website adafruit says
that i give problem, and need more power over 10 product in serie?
thanks
jean
angelstar
by angelstar on Thu Feb 28, 2019 4:57 am
another question
flora 2 or neopixel are the same led ws21812 B led?
i have this product who work with 5volt 10 Amp 50 watt
https://www.amazon.fr/gp/product/B01CDT ... ZTR8&psc=1
i want to put after this product some flora 2 , possible?
thanks
angelstar
by adafruit_support_bill on Thu Feb 28, 2019 7:21 am
Please show me where it says that.
As stated above, to power these pixels, you wire them in parallel - not in series.
At most, they will need 60mA each.
Yes. They are the same ws2112B LEDs.
With 144 pixels, it can draw as much as 60mA * 144 = 8640mA = 8.64A.
It should be possible to use those with the Flora pixels - if you power them all from the same source.
by angelstar on Thu Feb 28, 2019 8:43 am
thanks a lot
angelstar
