pi@raspberrypi:~/io-client-python/examples/basics $ sudo python3 environmental_monitorKBS.py
File "/usr/local/lib/python3.5/dist-packages/adafruit_bus_device/i2c_device.py", line 68, in __init__
i2c.writeto(device_address, b'')
File "/usr/local/lib/python3.5/dist-packages/busio.py", line 65, in writeto
return self._i2c.writeto(address, buffer, stop=stop)
File "/usr/local/lib/python3.5/dist-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 38, in writeto
self._i2c_bus.write_bytes(address, buffer[start:end])
File "/usr/local/lib/python3.5/dist-packages/Adafruit_PureIO/smbus.py", line 244, in write_bytes
self._device.write(buf)
OSError: [Errno 121] Remote I/O error
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.5/dist-packages/adafruit_bus_device/i2c_device.py", line 74, in __init__
i2c.readfrom_into(device_address, result)
File "/usr/local/lib/python3.5/dist-packages/busio.py", line 55, in readfrom_into
return self._i2c.readfrom_into(address, buffer, stop=stop)
File "/usr/local/lib/python3.5/dist-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 44, in readfrom_into
readin = self._i2c_bus.read_bytes(address, end-start)
File "/usr/local/lib/python3.5/dist-packages/Adafruit_PureIO/smbus.py", line 155, in read_bytes
return self._device.read(number)
File "environmental_monitorKBS.py", line 79, in <module>
uv = adafruit_veml6070.VEML6070(i2c)
File "/usr/local/lib/python3.5/dist-packages/adafruit_veml6070.py", line 130, in __init__
self.i2c_cmd = I2CDevice(i2c_bus, _VEML6070_ADDR_CMD)
File "/usr/local/lib/python3.5/dist-packages/adafruit_bus_device/i2c_device.py", line 76, in __init__
raise ValueError("No I2C device at address: %x" % device_address)
ValueError: No I2C device at address: 38
pi@raspberrypi:~/io-client-python/examples/basics $ i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
