how i test Multilayer Ceramic Capacitors
How to test Multilayer Ceramic Capacitors
- westfw
Re: How to test Multilayer Ceramic Capacitors
You mean to find their value? The usual technique is to throw them into something like a 555 oscillator and measure the resulting frequency.
(actually, the usual technique is probably to use the "capacitance" range available on many mid-range multimeters.)
multimeters or "RLC"/cap meters are considered to be the best way
thank you westfw for your replywestfw wrote:You mean to find their value? The usual technique is to throw them into something like a 555 oscillator and measure the resulting frequency.
What I want to know is whether this is Works well or damaged like this
by using multimeter
when its ok What should be on the multimeter
Can you please tell me how can I use the multimeter to test it ??adafruit wrote:multimeters or "RLC"/cap meters are considered to be the best way
read the multimeter manual
- zener
Put it on OHMS. If it is cracked it will be shorted. If it is not cracked then it will read changing ohms as it charges or just "OL". If it is shorted it will read <100 ohms, possibly much less, like zero or 1 or 2 ohms, 5 ohms etc. I have never seen them crack except 1812 size.
