Long Range Network (~1 mile)
by brentschmidt on Wed Mar 06, 2019 4:26 pm
Looking for a long range network to turn on and off irrigation wells on a farm. Each location would need to simply control 1-2 relays. Would like to also measure pressure, voltage, a-c current, and maybe flow rate at each location.
Would a Feather M0 with RFM95 LoRa Radio - 900MHz - RadioFruit, or a raspberry pi zero with a Adafruit LoRa Radio Bonnet be good platforms? I think I would prefer the raspberry pi all things equal.
brentschmidt
Re: Long Range Network (~1 mile)
by millercommamatt on Wed Mar 06, 2019 7:12 pm
1 mile is within the range of what LoRa can do but you'll likely need good antennas and line-of-site.
millercommamatt
by brentschmidt on Wed Mar 06, 2019 10:55 pm
Will the Raspberry Pi or the Feather be good platforms for this?
brentschmidt
by brentschmidt on Wed Mar 06, 2019 11:12 pm
Is Lora Necessary for this Range? Pros/Cons vs WIFI? Power is not an issue..
brentschmidt
by franklin97355 on Wed Mar 06, 2019 11:14 pm
Either will work fine. Your choice will be in whether you want a "controller" or a "computer"
franklin97355
by millercommamatt on Thu Mar 07, 2019 11:31 am
You would need a more expensive antenna to get 1 mile range for WiFi. If you do some searching, you'll see direction antenna kits for WiFi routers. It looks like you can get the antenna for well below $100 each. You could set up a WiFi bridge using those. You'll still need line-of-sight and you'll probably have to spend a few hundred dollars to get everything working. Ubiquiti sells some turn-key WiFi bridge systems that are competitively priced.
There are several ways to so this. It's just a matter of you budgets for time, money, and complexity.
millercommamatt
by brentschmidt on Thu Mar 07, 2019 9:19 pm
What is the difference between these two boards?
Adafruit Feather M0 with RFM95 LoRa Radio - 900MHz - RadioFruit
Adafruit Feather M0 RFM69HCW Packet Radio - 868 or 915 MHz - RadioFruit
brentschmidt
by franklin97355 on Thu Mar 07, 2019 9:30 pm
The radio chip onboard. You can see the differences in this tutorial.
franklin97355
by brentschmidt on Mon Mar 18, 2019 5:42 pm
About to pull the trigger on this. I have the following items in my shopping cart.
https://www.adafruit.com/product/3178 Adafruit Feather M0 with RFM95 LoRa Radio - 900MHz - RadioFruit
https://www.adafruit.com/product/3191 Adafruit Power Relay FeatherWing
https://www.adafruit.com/product/2900 Adafruit FeatherWing OLED - 128x32 OLED Add-on For Feather
https://www.adafruit.com/product/3340 900Mhz Antenna Kit - For LoPy, LoRa, etc
Also adafruit is out of stock on uFL SMT Antenna Connectors, so I found the following one at Mouser. Is this the best connector to use here?
https://www.mouser.com/ProductDetail/Taoglas/RECE-20279-001E-01?qs=WUa1z%2FNV9%252B3mVij1vDlP0A%3D%3D&gclid=Cj0KCQjwg73kBRDVARIsAF-kEH_SNmB3bWnt8yJPSM45FN8D6HRRZ6_Ny_40HLJKo6UjZBf4Uwto1SwaAiTREALw_wcB
Looking for appropriate enclosures. If I mount inside the the existing pump control panels (https://motorsandcontrol.com/brands/siemens-furnas/motor-starters-contactors/siemens-pump-panels/) I was thinking of using the Small Plastic Project Enclosure - Weatherproof with Clear Top. This will be extreme hot and cold environments (10-110 *F ambient temperature depending on season. Definitely hotter in the pump control panel). Is temperature a concern here? Also would need to run the LoRa cable through the enclosure and the pump control panel (any suggestions for mounting an antenna to the pump control panel?).
https://www.adafruit.com/product/903?gclid=Cj0KCQjwg73kBRDVARIsAF-kEH8iji5Be5-aEf9Ms1cpe3Ime-1u5NqZ0Rf8m9G9cvFJxI06u9b_IGgaAqXSEALw_wcB
If I mount it outside the existing pump control panel I was thinking of using a WH-06 WH Series Hinged NEMA Enclosure from Polycase.
https://www.polycase.com/wh-06.
All of the existing panels are 480V, so I am planning to use a transformer to convert to 110V to power the Feather. The relay FeatherWing is only rated up to 240V, so I also need another contact to complete the 480V circuit to complete the pump control circuit. Is there a simpler method here?
brentschmidt
by brentschmidt on Sat Mar 30, 2019 10:34 pm
Thinking of running the 3.3V on the M0 Feather through this relay and back to on of the GPIO pins of the M0 Feather. Is this a legitimate method for getting a hi/low signal to the Feather? Do I need to fuse this signal? Do I need to buffer the signal?
brentschmidt
by franklin97355 on Sun Mar 31, 2019 12:08 am
That is a 120 VAC relay coil and would not work. Most relays will not work directly from the Feather because the current needed is more than the Feather can supply.
franklin97355
by brentschmidt on Sun Mar 31, 2019 10:51 pm
I'm not looking to energize the relay with the feather. I'm trying to figure a creative way to get a 3v signal to the feather......
brentschmidt
by franklin97355 on Sun Mar 31, 2019 11:12 pm
If you are looking to get the relay output to the Feather it would be better to run between the GPIO pin and ground with a pull-up resistor. You would not need any resistor in the relay line.
franklin97355
by brentschmidt on Sun Jul 21, 2019 5:59 pm
franklin97355 wrote:If you are looking to get the relay output to the Feather it would be better to run between the GPIO pin and ground with a pull-up resistor. You would not need any resistor in the relay line.
I've had to set this project aside for a while and I'm just getting back to it.
If I understand you correctly I would Create a circuit from the 3V supply on the feather, through a resistor, through the normally closed relay to the ground. The GPIO pin would be connected between the resistor and relay. Is this correct?
brentschmidt
