Hello
I have a RS 485 converter and two Lora Feather Boards. The data is provided to the RS 485 converter vis putty and this data is transferred to first Lora Feather Board via serial communication. This data from first LORA feather board is transferred wirelessly to the second LORA feather board using the Radiohead library available on the LORA website. I am able to transfer the data from RS485 to first LORA board via serial communication. However, I am having issues in transferring the data using the Radiohead library to the second feather board. For example, if I am trying to send char 'a' using the library, on the second Lora feather board I am receiving the data but it is received in binary form. For example, if I send char 'a', I am receiving the binary version of 'a' i.e 1100001.
Can anyone help me on this issue?
Trasnmitter side code:
char *p = bufRX485, str, br, output[9];
int i , n , rs485count = 0;
for (i = 0; i <= 1000; i++) {
if (Serial1.available()) {
br = Serial1.read();
Serial.println(br);
*p = br;
p++;
rs485count++;
itoa(br, output, 2);
puts(output);
++br;
rf95.send((uint8_t*)output, sizeof(output));
rf95.waitPacketSent();
Receiver Side code:
uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
uint8_t len = sizeof(buf);
if (rf95.recv(buf, &len))
digitalWrite(LED, HIGH);
RH_RF95::printBuffer("Received: ", buf, len);
Serial.print("Got: ");
Serial.println((char*)buf);
Serial.print("RSSI: ");
Serial.println(rf95.lastRssi(), DEC);
Thanks in advance
Radiohead Library for data transmission
Re: Radiohead Library for data transmission
Try using this to convert the byte array into a String object:
String str = String( buf );
- vishu_fcb
I tried using the command:
But it shows the following error:
call of overloaded 'String(uint8_t [251])' is ambiguous
Try adding an explicit typecast:
String str = String( (unsigned char *)buf );
- vishu_fcb
I tried but it still shows this error :
call of overloaded 'String(unsigned char*)' is ambiguous
is there any specific type casting problem?
The Arduino IDE adds a bunch of type interpolation rules to make the low-level libraries compile properly, and sometimes that creates problems for other code.
Check over in the Arduino forums:
http://forum.arduino.cc/
The folks there will have the most recent information.
