Error on upload WordClock by Doro in MakeV67,
by Johnneff1 on Fri Apr 19, 2019 12:55 pm
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Pro Trinket 5V/16MHz (USB)"
Sketch uses 444 bytes (1%) of program storage space. Maximum is 28672 bytes.
Global variables use 9 bytes of dynamic memory.
An error occurred while uploading the sketch
Invalid library found in C:\Users\Lenovo User\Documents\Arduino\libraries\WordClock-NeoMatrix8x8-master: no headers files (.h) found in C:\Users\Lenovo User\Documents\Arduino\libraries\WordClock-NeoMatrix8x8-master
Invalid library found in C:\Users\Lenovo User\Documents\Arduino\libraries\WordClock_NeoMatrix8x8: no headers files (.h) found in C:\Users\Lenovo User\Documents\Arduino\libraries\WordClock_NeoMatrix8x8
Johnneff1
Re: Error on upload WordClock by Doro in MakeV67,
by adafruit_support_mike on Fri Apr 19, 2019 1:40 pm
The folder WordClock_NeoMatrix8x8 doesn’t go into your sketchbook/libraries folder. It’s a collection of sketches that run the Word Clock, not files that get #included in other sketches.
Move it back out to the sketchbook folder and things should work.
by Johnneff1 on Fri Apr 19, 2019 1:57 pm
thank you.
Johnneff1
by jimml1 on Sat Aug 10, 2019 2:39 pm
When I Try to upload I am getting this error.
__________________________________________________________________
Arduino: 1.8.9 (Mac OS X), Board: "Pro Trinket 5V/16MHz (USB)"
Sketch uses 14740 bytes (51%) of program storage space. Maximum is 28672 bytes.
Global variables use 610 bytes of dynamic memory.
Location
Users
Username
Documents
Arduino
Wordclock_Neomatrix8x8
Library
Adafruit_NeoMatrix
Adafruit_NeoPixel
Adafruit-GFX-Library
DST_RTC
RTClib
When I just do a compile (Verify) it complies without any errors.
jimml1
by adafruit_support_mike on Sat Aug 10, 2019 6:42 pm
Make sure you have the timing right when you press the reset button. The red LED on the Pro Trinket needs to be pulsing when the Arduino IDE is ready to upload the firmware.
by jimml1 on Sat Aug 10, 2019 7:51 pm
The green led is on solid, and the red led flashes 4 times, short pause, 4 flashes, short pause, etc.
jimml1
by adafruit_support_mike on Sat Aug 10, 2019 7:57 pm
That probably means you have a sketch that blinks the LED loaded into firmware.
The Pro Trinket bootloader should pulse the red LED for 10 seconds after you press the reset button.
by jimml1 on Sat Aug 10, 2019 8:50 pm
Now for some reason the red LED pulses when I plug the USB into the computer.
It keeps pulsing as long as the USB is plugged in. If I press the reset button
the red LED goes dark and resumes pulsing when the reset is released.
Still get the error when I try to upload when the red LED is pulsing.
jimml1
by adafruit_support_mike on Sun Aug 11, 2019 12:22 pm
Post a photo showing your hardware and connections and we’ll take a look. 800x600 images usually work best.
by jimml1 on Sun Aug 11, 2019 3:25 pm
I don't know if it makes any difference, but I don't have the CR1220 battery installed on the RTC yet.
I should have the battery tomorrow or tuesday.
Attached are the photos of the boards.
jimml1
by jimml1 on Sun Aug 11, 2019 3:26 pm
Two More Photos
jimml1
by adafruit_support_mike on Mon Aug 12, 2019 9:58 pm
It looks like you have a blob of solder across the resistor next to the connections on the NeoPixel matrix.
Clear that away and see if anything changes.
by jimml1 on Mon Aug 12, 2019 10:03 pm
No that is a reflection. I double checked. that area is clean.
jimml1
by jimml1 on Mon Aug 12, 2019 10:05 pm
I installed the battery but the error is still there.
I also tried uploading some example sketches, and I keep getting the same error.
jimml1
by jimml1 on Tue Aug 13, 2019 8:20 pm
I got a new pro tinker and rtc and am having the same problem.
I set Show verbose output during upload.
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v2 -Pusb -Uflash:w:/var/folders/bh/8_5rhhyj5bjb0jbh1mww9v3m0000gp/T/arduino_build_496083/WordClock_NeoMatrix8x8.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/frank James/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : stk500v2
avrdude: usbdev_open(): did not find any USB device "usb" (0x03eb:0x2104)
avrdude done. Thank you.
It looks like it does not see the usb port.
Any ideas ?
jimml1
