Adafruit 16-Channel 12-bit PWM/Servo HAT
by DLH_OldGuy on Tue Apr 23, 2019 7:33 pm
Once I have run a program on this is there a command or a program that I can run to reset the board. Currently the channels continue to perform the last commands given them. The only other alternative is to power down the R Pi.
Any suggestions?
Regards
DLH_OldGuy
Re: Adafruit 16-Channel 12-bit PWM/Servo HAT
by adafruit_support_mike on Wed Apr 24, 2019 1:25 am
That's normal. The PCA9685 keeps generating whatever PWM duty cycle you told it, until you tell it to do another.
You can make a quick script that runs through all the channels and sets their duty cycles to zero. That should clean up after any program that doesn't zero the channels by itself.
by DLH_OldGuy on Wed Apr 24, 2019 10:41 am
Thanks.
DLH_OldGuy
