VL53L0X Current usage
by PikesPeakAdafruit on Tue Apr 23, 2019 10:50 pm
I'm building a project that uses 9 VL53L0X boards. Three are on a single board that I made, and each of those has an AMS1117-50 1 amp voltage regulator.
It's controlled by a Raspberry Pi 3 B+, and if I keep all the '53's in shutdown mode, I can access any of the 9 over I2C. It works pretty well.
I've burned out (let out the magic smoke!) several of the AMS1117-50s, and I'm not sure why. They are good for only about 1 amp at 5 volts. Can you tell me how much current the VL53L0X uses, both when active and in shutdown mode?
Thanks for your help!
Steve Sibert
PikesPeakAdafruit
Re: VL53L0X Current usage
by adafruit_support_mike on Wed Apr 24, 2019 1:29 am
The V53L0X only uses about 20mA when the laser is active, and less than 10uA when idle. That shouldn't add enough load to kill a voltage regulator.
