Adafruit Programming Help
by anini119 on Wed Apr 24, 2019 12:51 pm
  Adapted from Bluefruit LE Connect Plotter
  for Feather Bluefruit -> Bluefruit LE Connect app
  (MIT License)
#include <Arduino.h>
#include <SPI.h>
#if not defined (_VARIANT_ARDUINO_DUE_X_) && not defined (_VARIANT_ARDUINO_ZERO_)
#include <SoftwareSerial.h>
#endif
#include "Adafruit_BLE.h"
#include "Adafruit_BluefruitLE_SPI.h"
#include "Adafruit_BluefruitLE_UART.h"
#include "BluefruitConfig.h"
#define FACTORYRESET_ENABLE         1
#define MINIMUM_FIRMWARE_VERSION    "0.6.6"
#define MODE_LED_BEHAVIOUR          "MODE"
// Data to plot
#define NUMBER 143
int data[NUMBER] = {-1.00627745,-1.00064115,-0.9947667,-0.98881285,-0.982859,-0.9767464,-0.9707132,-0.96491815,-0.95920245,-0.9534868,-0.9479299,-0.9422936,-0.9365779,-0.931021,-0.9253847,-0.91966905,-0.9139534,-0.9083171,-0.9026014,-0.8969651,-0.8912494,-0.8855337,-0.879818,-0.8741817,-0.86846605,-0.86298855,-0.85743165,-0.85179535,-0.84607965,-0.84036395,-0.83464825,-0.82885315,-0.8231375,-0.81734245,-0.8116268,-0.80606985,-0.80035415,-0.79463845,-0.78892275,-0.7831277,-0.77741205,-0.77177575,-0.76613945,-0.7604238,-0.7547875,-0.7491512,-0.7434355,-0.7377198,-0.7320835,-0.7264472,-0.7208109,-0.7151746,-0.7095383,-0.703902,-0.6982657,-0.6926294,-0.6869931,-0.6813568,-0.67572055,-0.6701636,-0.6645273,-0.658891,-0.65317535,-0.64745965,-0.64182335,-0.63610765,-0.63047135,-0.62475565,-0.61911935,-0.61348305,-0.60784675,-0.60221045,-0.59649475,-0.59077905,-0.58514275,-0.5794271,-0.57363205,-0.56799575,-0.56228005,-0.5565644,-0.5509281,-0.54513305,-0.53949675,-0.53393985,-0.52830355,-0.52266725,-0.51711035,-0.51155345,-0.50591715,-0.50028085,-0.4945652,-0.48892895,-0.48337205,-0.47781515,-0.47209945,-0.46646315,-0.4609062,-0.4552699,-0.449713,-0.4441561,-0.4385992,-0.4330423,-0.427406,-0.4216903,-0.4158952,-0.4101795,-0.40438445,-0.3986688,-0.39295315,-0.3872375,-0.3815218,-0.3757267,-0.370011,-0.3642953,-0.358659,-0.3529433,-0.34730705,-0.3415914,-0.3358757,-0.33016,-0.3244443,-0.318808,-0.3131717,-0.3075354,-0.304752789,-0.301925611,-0.299139353,-0.2963025,-0.2935108,-0.2906605,-0.287860231,-0.2851225,-0.28232,-0.2795921,-0.276787222,-0.2738765,-0.271041286,-0.2683195,-0.2657792,-0.2631595,-0.260381,-0.2572055,-0.25403};
int counter = 0;
// Create the Bluefruit Object
Adafruit_BluefruitLE_SPI ble(BLUEFRUIT_SPI_CS, BLUEFRUIT_SPI_IRQ, BLUEFRUIT_SPI_RST);
// A small helper
void error(const __FlashStringHelper*err) {
  Serial.println(err);
  while (1);
 * Setup
void setup(void)
  // Set up Serial output
  Serial.begin(115200);
  Serial.println(F("Adafruit Bluefruit Data Plotting"));
  Serial.println(F("------------------------------------------------"));
  /* Initialise the module */
  Serial.print(F("Initialising the Bluefruit LE module: "));
  if ( !ble.begin(VERBOSE_MODE) )
    error(F("Couldn't find Bluefruit, make sure it's in CoMmanD mode & check wiring?"));
  Serial.println( F("OK!") );
  if ( FACTORYRESET_ENABLE )
    /* Perform a factory reset to make sure everything is in a known state */
    Serial.println(F("Performing a factory reset: "));
    if ( ! ble.factoryReset() ) {
      error(F("Couldn't factory reset"));
  /* Disable command echo from Bluefruit */
  ble.echo(false);
  Serial.println("Requesting Bluefruit info:");
  /* Print Bluefruit information */
  ble.info();
  Serial.println(F("Please use Adafruit Bluefruit LE app to connect in UART mode"));
  Serial.println(F("Then Enter characters to send to Bluefruit"));
  Serial.println();
  ble.verbose(false);  // debug info is a little annoying after this point!
  /* Wait for connection */
  while (! ble.isConnected()) {
    delay(500);
  Serial.println(F("******************************"));
  // LED Activity command is only supported from 0.6.6
  if ( ble.isVersionAtLeast(MINIMUM_FIRMWARE_VERSION) )
    // Change Mode LED Activity
    Serial.println(F("Change LED activity to " MODE_LED_BEHAVIOUR));
    ble.sendCommandCheckOK("AT+HWModeLED=" MODE_LED_BEHAVIOUR);
  // Set module to DATA mode
  Serial.println( F("Switching to DATA mode!") );
  ble.setMode(BLUEFRUIT_MODE_DATA);
 delay(5000);                  //wait 1 second
  // Plot values in data array
  for (int i=0; i<NUMBER; i++) {
    ble.print(String( data[ i ] ).c_str());
    if (i < NUMBER-1) {
      ble.println()
  // plot the values
void loop () {
I having an error in plotting the given data values of the String.
Can you help with this?
anini119
Re: Adafruit Programming Help
by franklin97355 on Wed Apr 24, 2019 1:07 pm
Can you describe what you are trying to do and what error you are getting?
franklin97355
by anini119 on Wed Apr 24, 2019 1:19 pm
The values in the data array are negative and positive and are in decimal values.
I'm not able to plot these values using the BLE application.
Can you help me with the code?
anini119
