1586 light ring
1586 light ring
by ddgjim on Fri Apr 26, 2019 4:21 pm
I'm working on a project and trying to create sample display jars that will have a white LED light ring in the cap. The 1586 ring seems to be the right size, but I don't know how to power it. The jars will be sitting on a counter and I need a way to power the light with rechargable battery power. Also need a way to turn the light on an off. Would like to have them turn on when the jar is picked up, and turn off when the jar is placed back on the counter.
Can you suggest which products I should purchase to make this happen. I'm working on a proto type now and will need to make 50 jars once I get everything figured out.
I appreciate any help you can give me.
Jim
ddgjim
Re: 1586 light ring
by adafruit_support_bill on Fri Apr 26, 2019 6:22 pm
Neopixels can be powered with a power source between 3.7v and 5.v. For portable projects, a 3.7v LiPo battery is ideal.
However, just a power source will not light them up. You need a microcontroller programmed to send them commands to light up. Something like an M0 Trinket or Feather M0 would be good choices. The Feather is a bit more expensive, but has a built-in LiPo battery charger.
https://www.adafruit.com/product/3500
https://www.adafruit.com/product/2772
Re: 1586 light ring
by BSHINMACHI on Thu Jul 18, 2019 9:01 pm
We are using the 1586 (NeoPixel Ring – 24x 5050 RGB LED with Integration Drivers) and under the TECHNICAL DETAILS, it states “May ship with either WS2812B or SK6812-based LEDs. They are the same brightness, color and protocol”. However, the LED intensity levels are different between WS2812B and SK6812. Therefore, I need the following:
1. Latest datasheet for WS2812B and SK6812 components.
2. Document stating 1586 conforms to the latest RoHS compliancy (10 restricted sustances by RoHS Directive)?
3. Is the statement still true about the product 1586 will either be WS2812B or SK6812-based LEDs?
4. Can you confirm that the product 1586 will have the SAME LEDs (not mixing WS2812B and SK6812)?
BSHINMACHI
Re: 1586 light ring
by adafruit_support_bill on Fri Jul 19, 2019 5:45 am
Currently all Neopixel rings are shipping with SK6812 pixels. There are links on the product page to data sheets:
https://cdn-shop.adafruit.com/product-f ... sheet+.pdf
Re: 1586 light ring
by BSHINMACHI on Fri Jul 19, 2019 10:36 am
adafruit_support_bill wrote:Currently all Neopixel rings are shipping with SK6812 pixels. There are links on the product page to data sheets:
Thank you for the reply which answers my questions (1,3,4)...however, I still need the following:
BSHINMACHI
Re: 1586 light ring
by adafruit_support_bill on Fri Jul 19, 2019 11:08 am
See the attached:
rohs_1586.pdf
(30.84 KiB) Downloaded 36 times
Re: 1586 light ring
by BSHINMACHI on Fri Jul 19, 2019 12:09 pm
adafruit_support_bill wrote:See the attached:
Thanks Bill. Unfortunately, that RoHS certificate does not cover the most up-to-date regulatory requirements for RoHS. Attached is an image showing the 4 missing items from the document.
List of missing 4 items for latest RoHS requirements
Adafruit 1586 RoHS (Missing 4 RoHS items).png (756.07 KiB) Viewed 125 times
BSHINMACHI
Re: 1586 light ring
by adafruit_support_bill on Sat Jul 20, 2019 5:38 am
See updated certification attached:
RoHS 2 cert P1586 on 7.19.19.pdf
(175.34 KiB) Downloaded 18 times
