Xbee arduino
Xbee arduino
by drummerboyx on Mon Mar 29, 2010 5:15 pm
Is it possible for there to be 1 x bee module communicating with maybe 2-4 separately? For example, have 1 master arduino controlling 3 others independently.
Any ideas??
Elijah
drummerboyx
Re: Xbee arduino
by franklin97355 on Mon Mar 29, 2010 5:27 pm
Yes, it's possible.
franklin97355
Re: Xbee arduino
by drummerboyx on Mon Mar 29, 2010 11:24 pm
Is it possible to have a xbee pro (100mw) and a xbee (1mw) communicating? And if I have the 1mw xbee a mile away, can it still receive data from the 100mw xbee, but not send back data?
Elijah
drummerboyx
Re: Xbee arduino
by adafruit on Tue Mar 30, 2010 11:00 am
you can mix and match pro and notpro but xbees are not 'stupid' and need to be able to communicate both ways
so youd need two xbee pros
Re: Xbee arduino
by drummerboyx on Tue Mar 30, 2010 11:20 am
Well, what I'm planning on doing is get 1 xbee pro (that has a 15 mile range!) on a master arduino. Then have "zones" of other arduino boards within a 300ft distance from the master arduino. I also want to set up an arduino a couple miles away from the master arduino (this arduino will have the xbee pro that has a longer range). My plan is that the "zones" of arduinos, including the one that is a couple miles away, all being controlled by 1 master arduino.
Is this possible?
Sorry if I'm getting a little confusing... (-;
Elijah
drummerboyx
Re: Xbee arduino
by adafruit on Tue Mar 30, 2010 12:39 pm
sure
Re: Xbee arduino
by franklin97355 on Tue Mar 30, 2010 6:25 pm
Just be aware the 15 mile xbee is a 900mhz device and is used with high gain antennas. Not your normal 2.4g xbees.
franklin97355
