Neopixel Functions
Neopixel Functions
by BURevisfan on Thu Jun 13, 2019 11:33 am
At the suggestion of the forums, I'm using this method of setting up the Neopixel functions because I need to run two strips simultaneously with different function.
https://learn.adafruit.com/multi-taskin ... 3/overview
Now what I need help with... How do I write the code so the LED function only executes once.
For example, I want my Neopixels to fade from black/off to full red once and then stay at red until I tell them otherwise.
Right now with the fade function they fade up, pause, then start over
thanks,
Robert
BURevisfan
Re: Neopixel Functions
by franklin97355 on Thu Jun 13, 2019 12:20 pm
Post the code you have so we can see where you need to make changes. Please use code tags when posting code or logs to the forums. It preserves formatting and makes it easier for everyone to read the code. Click the code button above the reply box and past your code between the tags created.
franklin97355
by adafruit_support_bill on Thu Jun 13, 2019 12:21 pm
Add a completion callback and use it to set the ActivePattern to None.
https://learn.adafruit.com/multi-taskin ... backs-11-9
by BURevisfan on Thu Jun 13, 2019 12:36 pm
Thank you so much!
I forgot about the completion callbacks. That should accomplish what I need
BURevisfan
