Pi Zero W Failed Video & USB
by bigsur on Thu Jun 13, 2019 9:33 pm
Hello!
Zay in Support requested I post this here to get approval for exchange. Here's the trouble with my Pi Zero W:
What doesn't work:
- Video out via HDMI - no signal, not even the color palette.
- USB input - Caps lock light does not illuminate when depressed and I "blind typing" to log in and shutdown has no affect.
What does work:
- Power: LED illuminates
- WiFi: I can Ping and SSH into the unit via WiFi correctly.
- Pi Camera: Works correclty (I've created a web server and web-app to view the feed)
- GPIO: Python script accurately records the input.
What I've tried:
- 2 different SD cards with bootable systems - both give same results as above.
- 2 different TVs/displays - both which used to work, now don't.
Order details:
- Order Confirmation No: 2020692-4630105218
- Item: 1 x Raspberry Pi Zero WH (Zero W with Headers)[ID:3708]
- Order Date 3/28/2019
Thank you in advance for your support!
bigsur
Re: Pi Zero W Failed Video & USB
by adafruit_support_mike on Mon Jun 17, 2019 12:44 am
Those will be separate issues, but they might both show up when the RasPi does its hardware recognition process while booting.
Post the output from the command `dmesg` between CODE tags please. That will tell us what the kernel thinks.
by bigsur on Mon Jun 17, 2019 8:38 am
Thank you for your help. Here's the output from dmesg.
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.98+ (dom@dom-XPS-13-9370) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1200 Tue Feb 12 20:11:02 GMT 2019
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi Zero W Rev 1.1
[    0.000000] Memory policy: Data cache writeback
[    0.000000] cma: Reserved 8 MiB at 0x17400000
[    0.000000] On node 0 totalpages: 98304
[    0.000000] free_area_init_node: node 0, pgdat c09caaf0, node_mem_map d7c8a100
[    0.000000]   Normal zone: 864 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 98304 pages, LIFO batch:31
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 97440
[    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:17:F8:AF vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=72cfad0c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 370248K/393216K available (6451K kernel code, 589K rwdata, 1992K rodata, 440K init, 673K bss, 14776K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xd8800000 - 0xff800000   ( 624 MB)
                   lowmem  : 0xc0000000 - 0xd8000000   ( 384 MB)
                   modules : 0xbf000000 - 0xc0000000   (  16 MB)
                     .text : 0xc0008000 - 0xc0655050   (6453 kB)
                     .init : 0xc08d4000 - 0xc0942000   ( 440 kB)
                     .data : 0xc0942000 - 0xc09d54f8   ( 590 kB)
                      .bss : 0xc09dadf0 - 0xc0a8338c   ( 674 kB)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] ftrace: allocating 24128 entries in 71 pages
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000029] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[    0.000074] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    0.000168] bcm2835: system timer (irq = 27)
[    0.000749] Console: colour dummy device 80x30
[    0.001352] console [tty1] enabled
[    0.001405] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[    0.060341] pid_max: default: 32768 minimum: 301
[    0.060859] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.060914] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.062248] Disabling memory control group subsystem
[    0.062466] CPU: Testing write buffer coherency: ok
[    0.063645] Setting up static identity map for 0x8200 - 0x8238
[    0.064932] devtmpfs: initialized
[    0.074458] random: get_random_u32 called from bucket_table_alloc+0x88/0x1c4 with crng_init=0
[    0.075375] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    0.075806] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.075879] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.077229] pinctrl core: initialized pinctrl subsystem
[    0.078646] NET: Registered protocol family 16
[    0.081622] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.088146] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.088220] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.088367] Serial: AMBA PL011 UART driver
[    0.091347] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[    0.092141] uart-pl011 20201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[    0.131358] bcm2835-dma 20007000.dma: DMA legacy API manager at d880d000, dmachans=0x1
[    0.133711] SCSI subsystem initialized
[    0.133996] usbcore: registered new interface driver usbfs
[    0.134136] usbcore: registered new interface driver hub
[    0.134372] usbcore: registered new device driver usb
[    0.140818] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-03-27 15:48
[    0.142865] clocksource: Switched to clocksource timer
[    0.228789] VFS: Disk quotas dquot_6.6.0
[    0.228971] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.229290] FS-Cache: Loaded
[    0.229651] CacheFiles: Loaded
[    0.246941] NET: Registered protocol family 2
[    0.248199] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.248332] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.248450] TCP: Hash tables configured (established 4096 bind 4096)
[    0.248630] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.248689] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.249065] NET: Registered protocol family 1
[    0.249831] RPC: Registered named UNIX socket transport module.
[    0.249890] RPC: Registered udp transport module.
[    0.249918] RPC: Registered tcp transport module.
[    0.249941] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.251847] hw perfevents: no irqs for PMU, sampling events not supported
[    0.251980] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[    0.255808] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.268116] FS-Cache: Netfs 'nfs' registered for caching
[    0.269507] NFS: Registering the id_resolver key type
[    0.269616] Key type id_resolver registered
[    0.269648] Key type id_legacy registered
[    0.269697] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.274546] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.275036] io scheduler noop registered
[    0.275087] io scheduler deadline registered (default)
[    0.275640] io scheduler cfq registered
[    0.275687] io scheduler mq-deadline registered
[    0.275718] io scheduler kyber registered
[    0.278031] BCM2708FB: allocated DMA memory 57500000
[    0.278143] BCM2708FB: allocated DMA channel 0 @ d880d000
[    0.286258] Console: switching to colour frame buffer device 82x26
[    0.296933] bcm2835-rng 20104000.rng: hwrng registered
[    0.299910] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    0.306345] vc-sm: Videocore shared memory driver
[    0.309729] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[    0.333790] brd: module loaded
[    0.348534] loop: module loaded
[    0.351204] Loading iSCSI transport class v2.0-870.
[    0.354744] usbcore: registered new interface driver smsc95xx
[    0.357490] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.388151] dwc_otg 20980000.usb: base=0xf0980000
[    0.591062] Core Release: 2.80a
[    0.593683] Setting default values for core params
[    0.596268] Finished setting default values for core params
[    0.799170] Using Buffer DMA mode
[    0.801832] Periodic Transfer Interrupt Enhancement - disabled
[    0.804563] Multiprocessor Interrupt Enhancement - disabled
[    0.807315] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.810165] Dedicated Tx FIFOs mode
[    0.813878] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xd7514000 dma = 0x57514000 len=9024
[    0.819454] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    0.832228] dwc_otg: Microframe scheduler enabled
[    0.832478] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc04a00d0
[    0.835149] WARN::hcd_init_fiq:460: FIQ ASM at 0xc04a03ac length 36
[    0.837716] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
[    0.840446] dwc_otg 20980000.usb: DWC OTG Controller
[    0.843184] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[    0.845916] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[    0.848557] Init: Port Power? op_state=1
[    0.851106] Init: Power Port (0)
[    0.853975] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.856612] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.859207] usb usb1: Product: DWC OTG Controller
[    0.861746] usb usb1: Manufacturer: Linux 4.14.98+ dwc_otg_hcd
[    0.864368] usb usb1: SerialNumber: 20980000.usb
[    0.868054] hub 1-0:1.0: USB hub found
[    0.870633] hub 1-0:1.0: 1 port detected
[    0.874034] dwc_otg: FIQ enabled
[    0.874046] dwc_otg: NAK holdoff enabled
[    0.874052] dwc_otg: FIQ split-transaction FSM enabled
[    0.874071] Module dwc_common_port init
[    0.874585] usbcore: registered new interface driver usb-storage
[    0.877544] mousedev: PS/2 mouse device common for all mice
[    0.880075] IR NEC protocol handler initialized
[    0.882535] IR RC5(x/sz) protocol handler initialized
[    0.885094] IR RC6 protocol handler initialized
[    0.887516] IR JVC protocol handler initialized
[    0.889848] IR Sony protocol handler initialized
[    0.892199] IR SANYO protocol handler initialized
[    0.894609] IR Sharp protocol handler initialized
[    0.896883] IR MCE Keyboard/mouse protocol handler initialized
[    0.899173] IR XMP protocol handler initialized
[    0.902730] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
[    0.905824] bcm2835-cpufreq: min=700000 max=1000000
[    0.908907] sdhci: Secure Digital Host Controller Interface driver
[    0.911373] sdhci: Copyright(c) Pierre Ossman
[    0.914464] mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
[    0.917631] sdhost-bcm2835 20202000.mmc: could not get clk, deferring probe
[    0.920342] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.923548] ledtrig-cpu: registered to indicate activity on CPUs
[    0.926317] hidraw: raw HID events driver (C) Jiri Kosina
[    0.929201] usbcore: registered new interface driver usbhid
[    0.931835] usbhid: USB HID core driver
[    0.935400] vchiq: vchiq_init_state: slot_zero = d7580000, is_master = 0
[    0.940070] [vc_sm_connected_init]: start
[    0.950336] [vc_sm_connected_init]: end - returning 0
[    0.954205] Initializing XFRM netlink socket
[    0.957003] NET: Registered protocol family 17
[    0.959843] Key type dns_resolver registered
[    0.964358] registered taskstats version 1
[    0.975161] uart-pl011 20201000.serial: cts_event_workaround enabled
[    0.978224] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[    0.986841] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
[    0.989804] mmc-bcm2835 20300000.mmc: DMA channel allocated
[    1.054395] sdhost: log_buf @ d7513000 (57513000)
[    1.094497] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.099111] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.103486] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.108951] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.131858] random: fast init done
[    1.142936] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    1.146638] of_cfs_init
[    1.149168] of_cfs_init: OK
[    1.152392] Waiting for root device PARTUUID=72cfad0c-02...
[    1.230290] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.237730] mmc0: new high speed SDXC card at address 0001
[    1.241400] mmcblk0: mmc0:0001 JD4RT 119 GiB
[    1.246682]  mmcblk0: p1 p2
[    1.265525] mmc1: new high speed SDIO card at address 0001
[    1.296395] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.301454] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.313445] devtmpfs: mounted
[    1.318521] Freeing unused kernel memory: 440K
[    1.321036] This architecture does not have kernel memory protection.
[    1.861759] systemd[1]: System time before build time, advancing clock.
[    2.016072] NET: Registered protocol family 10
[    2.020766] Segment Routing with IPv6
[    2.037221] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.064099] random: systemd: uninitialized urandom read (16 bytes read)
[    2.076288] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    2.086935] systemd[1]: Detected architecture arm.
[    2.111287] systemd[1]: Set hostname to <raspberrypi>.
[    2.160697] random: systemd: uninitialized urandom read (16 bytes read)
[    2.382722] random: systemd-cryptse: uninitialized urandom read (16 bytes read)
[    3.263426] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.296947] systemd[1]: Reached target Swap.
[    3.305932] systemd[1]: Created slice User and Session Slice.
[    3.314054] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.322845] systemd[1]: Created slice System Slice.
[    3.331927] systemd[1]: Created slice system-getty.slice.
[    3.342182] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    6.607293] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    6.983842] systemd-journald[72]: Received request to flush runtime journal from PID 1
[    9.653320] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    9.681214] bcm2835_alsa bcm2835_alsa: card created with 8 channels
[   10.263266] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[   10.283433] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
[   10.283822] usbcore: registered new interface driver brcmfmac
[   10.758602] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
[   10.759831] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
[   14.070234] uart-pl011 20201000.serial: no DMA platform data
[   16.201475] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[   17.249572] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   17.249614] brcmfmac: power management disabled
[   18.185408] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   18.683216] Bluetooth: Core ver 2.22
[   18.683430] NET: Registered protocol family 31
[   18.683442] Bluetooth: HCI device and connection manager initialized
[   18.683476] Bluetooth: HCI socket layer initialized
[   18.683497] Bluetooth: L2CAP socket layer initialized
[   18.683581] Bluetooth: SCO socket layer initialized
[   18.705819] Bluetooth: HCI UART driver ver 2.3
[   18.705840] Bluetooth: HCI UART protocol H4 registered
[   18.705847] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   18.712982] Bluetooth: HCI UART protocol Broadcom registered
[   19.141018] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   19.141032] Bluetooth: BNEP filters: protocol multicast
[   19.141059] Bluetooth: BNEP socket layer initialized
bigsur
by adafruit_support_mike on Wed Jun 19, 2019 2:06 am
Hmm.. the messages show the USB hub being recognized and configured. Did you have the USB keyboard connected while the Zero was booting?
If not, what output do you get from the command `lsusb` when you connect a device to the OTG port?
I don't see any messages about the video system one way or another, but the mini-HDMI adapters can be flaky. Have you used the adapter with another Zero or Zero-W to confirm that it works?
by bigsur on Wed Jun 19, 2019 8:21 pm
adafruit_support_mike wrote:Hmm.. the messages show the USB hub being recognized and configured. Did you have the USB keyboard connected while the Zero was booting?
Hi Mike,
Video: I don't have any other Zero W (or other mini HDMI device) to check the HDMI adaptor with. But I did try with different cables to the adaptor and no change. :(
USB: I did have it connected at the time but tried again. This time the Caps Lock lights up when tapped, and it shows in lsusb. Although, it doesn't accept any blind input: pi / password. Maybe the first time I didn't have a tight fit.
Bus 001 Device 003: ID 05ac:020b Apple, Inc. Pro Keyboard [Mitsumi, A1048/US layout]
Bus 001 Device 002: ID 05ac:1003 Apple, Inc. Hub in Pro Keyboard [Mitsumi, A1048]
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Where do we go from here? Thank you.
bigsur
by bigsur on Wed Jun 19, 2019 8:51 pm
Video: I pulled out a 3rd, old display to try on as many devices as possible, and this one works. I'm glad to have some visibility, but I don't understand why my original, primary display won't connect. I've re-verified the config in /boot/config.txt and they match the appropriate settings for that display. I've even tried removing them and re-entering from a backup.
Although, with another set of cables, and after trying on the old display, I at least get a "flashing sync" light on my primary display, which is more than before. Here's the output of dmesg now:
[    0.000000] cma: Reserved 8 MiB at 0x1b400000
[    0.000000] On node 0 totalpages: 114688
[    0.000000] free_area_init_node: node 0, pgdat c09caaf0, node_mem_map db010000
[    0.000000]   Normal zone: 1008 pages used for memmap
[    0.000000]   Normal zone: 114688 pages, LIFO batch:31
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 113680
[    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1200 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:17:F8:AF vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=511cdec2-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] Memory: 435208K/458752K available (6451K kernel code, 589K rwdata, 1992K rodata, 440K init, 673K bss, 15352K reserved, 8192K cma-reserved)
                   vmalloc : 0xdc800000 - 0xff800000   ( 560 MB)
                   lowmem  : 0xc0000000 - 0xdc000000   ( 448 MB)
[    0.000073] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    0.000165] bcm2835: system timer (irq = 27)
[    0.000739] Console: colour dummy device 80x30
[    0.001341] console [tty1] enabled
[    0.001393] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[    0.060336] pid_max: default: 32768 minimum: 301
[    0.060855] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.060909] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.062250] Disabling memory control group subsystem
[    0.062468] CPU: Testing write buffer coherency: ok
[    0.064949] devtmpfs: initialized
[    0.074446] random: get_random_u32 called from bucket_table_alloc+0x88/0x1c4 with crng_init=0
[    0.075360] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    0.075796] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.075867] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.077218] pinctrl core: initialized pinctrl subsystem
[    0.078643] NET: Registered protocol family 16
[    0.081624] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.088149] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.088223] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.088373] Serial: AMBA PL011 UART driver
[    0.091352] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[    0.092139] uart-pl011 20201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[    0.131096] bcm2835-dma 20007000.dma: DMA legacy API manager at dc80d000, dmachans=0x1
[    0.133463] SCSI subsystem initialized
[    0.133750] usbcore: registered new interface driver usbfs
[    0.133909] usbcore: registered new interface driver hub
[    0.134152] usbcore: registered new device driver usb
[    0.140815] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-02-12 19:42
[    0.142869] clocksource: Switched to clocksource timer
[    0.228778] VFS: Disk quotas dquot_6.6.0
[    0.228960] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.229277] FS-Cache: Loaded
[    0.229653] CacheFiles: Loaded
[    0.246909] NET: Registered protocol family 2
[    0.248152] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.248284] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.248404] TCP: Hash tables configured (established 4096 bind 4096)
[    0.248584] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.248642] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.249017] NET: Registered protocol family 1
[    0.249784] RPC: Registered named UNIX socket transport module.
[    0.249841] RPC: Registered udp transport module.
[    0.249870] RPC: Registered tcp transport module.
[    0.249894] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.251794] hw perfevents: no irqs for PMU, sampling events not supported
[    0.251926] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[    0.255749] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.268129] FS-Cache: Netfs 'nfs' registered for caching
[    0.269512] NFS: Registering the id_resolver key type
[    0.269610] Key type id_resolver registered
[    0.269642] Key type id_legacy registered
[    0.269691] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.274582] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.275073] io scheduler noop registered
[    0.275124] io scheduler deadline registered (default)
[    0.275676] io scheduler cfq registered
[    0.275725] io scheduler mq-deadline registered
[    0.275755] io scheduler kyber registered
[    0.278069] BCM2708FB: allocated DMA memory 5b500000
[    0.278183] BCM2708FB: allocated DMA channel 0 @ dc80d000
[    0.332232] Console: switching to colour frame buffer device 240x75
[    0.378093] bcm2835-rng 20104000.rng: hwrng registered
[    0.378566] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    0.379996] vc-sm: Videocore shared memory driver
[    0.380871] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[    0.401643] brd: module loaded
[    0.415234] loop: module loaded
[    0.415431] Loading iSCSI transport class v2.0-870.
[    0.416572] usbcore: registered new interface driver smsc95xx
[    0.416839] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.445166] dwc_otg 20980000.usb: base=0xf0980000
[    0.645780] Core Release: 2.80a
[    0.645949] Setting default values for core params
[    0.646171] Finished setting default values for core params
[    0.846786] Using Buffer DMA mode
[    0.846962] Periodic Transfer Interrupt Enhancement - disabled
[    0.847179] Multiprocessor Interrupt Enhancement - disabled
[    0.847385] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.847646] Dedicated Tx FIFOs mode
[    0.848732] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xdb514000 dma = 0x5b514000 len=9024
[    0.849120] FIQ FSM acceleration enabled for :
[    0.849852] dwc_otg: Microframe scheduler enabled
[    0.850075] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc04a00d0
[    0.850318] WARN::hcd_init_fiq:460: FIQ ASM at 0xc04a03ac length 36
[    0.850561] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
[    0.850866] dwc_otg 20980000.usb: DWC OTG Controller
[    0.851128] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[    0.851471] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[    0.851733] Init: Port Power? op_state=1
[    0.851886] Init: Power Port (0)
[    0.852472] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.852734] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.853091] usb usb1: Product: DWC OTG Controller
[    0.853286] usb usb1: Manufacturer: Linux 4.14.98+ dwc_otg_hcd
[    0.853503] usb usb1: SerialNumber: 20980000.usb
[    0.854931] hub 1-0:1.0: USB hub found
[    0.855220] hub 1-0:1.0: 1 port detected
[    0.856493] dwc_otg: FIQ enabled
[    0.856507] dwc_otg: NAK holdoff enabled
[    0.856512] dwc_otg: FIQ split-transaction FSM enabled
[    0.856533] Module dwc_common_port init
[    0.857093] usbcore: registered new interface driver usb-storage
[    0.868349] mousedev: PS/2 mouse device common for all mice
[    0.878876] IR NEC protocol handler initialized
[    0.889295] IR RC5(x/sz) protocol handler initialized
[    0.899552] IR RC6 protocol handler initialized
[    0.909849] IR JVC protocol handler initialized
[    0.920183] IR Sony protocol handler initialized
[    0.930276] IR SANYO protocol handler initialized
[    0.940416] IR Sharp protocol handler initialized
[    0.950384] IR MCE Keyboard/mouse protocol handler initialized
[    0.960633] IR XMP protocol handler initialized
[    0.972550] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
[    0.983574] bcm2835-cpufreq: min=700000 max=1000000
[    0.994681] sdhci: Secure Digital Host Controller Interface driver
[    1.004975] sdhci: Copyright(c) Pierre Ossman
[    1.015918] mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
[    1.027105] sdhost-bcm2835 20202000.mmc: could not get clk, deferring probe
[    1.037725] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.048813] ledtrig-cpu: registered to indicate activity on CPUs
[    1.059455] hidraw: raw HID events driver (C) Jiri Kosina
[    1.070188] usbcore: registered new interface driver usbhid
[    1.080626] usbhid: USB HID core driver
[    1.091025] Indeed it is in host mode hprt0 = 00021501
[    1.163042] vchiq: vchiq_init_state: slot_zero = db580000, is_master = 0
[    1.175985] [vc_sm_connected_init]: start
[    1.189233] [vc_sm_connected_init]: end - returning 0
[    1.201222] Initializing XFRM netlink socket
[    1.212005] NET: Registered protocol family 17
[    1.222638] Key type dns_resolver registered
[    1.235430] registered taskstats version 1
[    1.255174] uart-pl011 20201000.serial: cts_event_workaround enabled
[    1.266123] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[    1.280095] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
[    1.290908] mmc-bcm2835 20300000.mmc: DMA channel allocated
[    1.302975] usb 1-1: new full-speed USB device number 2 using dwc_otg
[    1.313975] Indeed it is in host mode hprt0 = 00021501
[    1.414687] sdhost: log_buf @ db513000 (5b513000)
[    1.433583] random: fast init done
[    1.472831] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.485107] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.497369] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.510815] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.522958] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    1.535108] of_cfs_init
[    1.566740] of_cfs_init: OK
[    1.580531] usb 1-1: New USB device found, idVendor=05ac, idProduct=1003
[    1.590880] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.601094] usb 1-1: Product: Hub in Apple Extended USB Keyboard
[    1.611281] usb 1-1: Manufacturer: Mitsumi Electric
[    1.623499] Waiting for root device PARTUUID=511cdec2-02...
[    1.645939] hub 1-1:1.0: USB hub found
[    1.656887] hub 1-1:1.0: 3 ports detected
[    1.680690] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.693946] mmc0: new high speed SDXC card at address 0001
[    1.705653] mmcblk0: mmc0:0001 GC2QT 59.6 GiB
[    1.718848]  mmcblk0: p1 p2
[    1.772334] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.783701] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.805073] devtmpfs: mounted
[    1.818488] Freeing unused kernel memory: 440K
[    1.828840] This architecture does not have kernel memory protection.
[    1.866872] mmc1: new high speed SDIO card at address 0001
[    2.003011] usb 1-1.3: new full-speed USB device number 3 using dwc_otg
[    2.150474] usb 1-1.3: New USB device found, idVendor=05ac, idProduct=020b
[    2.161395] usb 1-1.3: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[    2.171884] usb 1-1.3: Product: Apple Extended USB Keyboard
[    2.182442] usb 1-1.3: Manufacturer: Mitsumi Electric
[    2.211338] input: Mitsumi Electric Apple Extended USB Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:05AC:020B.0001/input/input0
[    2.294339] hid-generic 0003:05AC:020B.0001: input,hidraw0: USB HID v1.10 Keyboard [Mitsumi Electric Apple Extended USB Keyboard] on usb-20980000.usb-1.3/input0
[    2.327707] input: Mitsumi Electric Apple Extended USB Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:05AC:020B.0002/input/input1
[    2.403432] hid-generic 0003:05AC:020B.0002: input,hidraw1: USB HID v1.10 Device [Mitsumi Electric Apple Extended USB Keyboard] on usb-20980000.usb-1.3/input1
[    2.526225] systemd[1]: System time before build time, advancing clock.
[    2.696203] NET: Registered protocol family 10
[    2.710421] Segment Routing with IPv6
[    2.737183] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.775004] random: systemd: uninitialized urandom read (16 bytes read)
[    2.797725] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    2.812247] systemd[1]: Detected architecture arm.
[    2.878512] systemd[1]: Set hostname to <piday>.
[    2.950584] random: systemd: uninitialized urandom read (16 bytes read)
[    3.219340] random: systemd-cryptse: uninitialized urandom read (16 bytes read)
[    4.270155] systemd[1]: Listening on fsck to fsckd communication Socket.
[    4.299843] systemd[1]: Listening on Journal Socket.
[    4.328220] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.356774] systemd[1]: Listening on udev Kernel Socket.
[    4.385319] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.415450] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    4.445010] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    8.289052] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    8.856950] systemd-journald[90]: Received request to flush runtime journal from PID 1
[   12.613377] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[   12.633466] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
[   12.633967] usbcore: registered new interface driver brcmfmac
[   13.120053] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
[   13.121417] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
[   17.959835] uart-pl011 20201000.serial: no DMA platform data
[   20.531601] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[   22.095997] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   22.096043] brcmfmac: power management disabled
[   22.718288] Bluetooth: Core ver 2.22
[   22.718445] NET: Registered protocol family 31
[   22.718455] Bluetooth: HCI device and connection manager initialized
[   22.718481] Bluetooth: HCI socket layer initialized
[   22.718495] Bluetooth: L2CAP socket layer initialized
[   22.718537] Bluetooth: SCO socket layer initialized
[   22.745386] Bluetooth: HCI UART driver ver 2.3
[   22.745404] Bluetooth: HCI UART protocol H4 registered
[   22.745411] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   22.752112] Bluetooth: HCI UART protocol Broadcom registered
[   23.243038] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   23.243055] Bluetooth: BNEP filters: protocol multicast
[   23.243088] Bluetooth: BNEP socket layer initialized
[   28.598092] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  144.667074] random: crng init done
[  144.667102] random: 7 urandom warning(s) missed due to ratelimiting
Thanks for any ideas!
bigsur
by adafruit_support_mike on Thu Jun 20, 2019 1:11 am
Try uncommenting this line in your /boot/config.txt file:
#config_hdmi_boost=4
The RasPi emits a weak HDMI signal by default to save power. It can be too weak for some displays, and displays connected through longer HDMI cables.
You can take the boost value up to 11, but values over 7 can cause physical damage to either the RasPi or a display.
by bigsur on Tue Jun 25, 2019 6:00 pm
adafruit_support_mike wrote:Try uncommenting this line in your /boot/config.txt file:
Thank you for the suggestion. I tried up to 6, but still no change. The display works fine with my other systems, just not this Pi. What's next?
bigsur
by adafruit_support_mike on Tue Jun 25, 2019 11:19 pm
Hrm.. if it weren't for the display that does show video, I'd call it a dead HDMI subsystem.
Do you happen to have another mini-HDMI adapter you can try? Those can also cause problems.
by bigsur on Thu Jun 27, 2019 9:22 am
adafruit_support_mike wrote:Hrm.. if it weren't for the display that does show video, I'd call it a dead HDMI subsystem.
This is my only Zero W, so I only have 1 mini-HDMI adaptor.
I agree it's strange that the Pi+Adaptor work on 1 monitor and not another, while that monitor works fine with other computers.
FWIW, the resolution of the non-working display is larger than the one it works on. I have been updating the boot/config.txt to match the correct display, using the same config settings from when it worked. See code below.
Have these adaptors been known to fail at larger resolutions?
Working: 22" Display /boot/config.txt:
hdmi_cvt=1600 1024 60
hdmi_group=2
hdmi_mode=87
hdmi_drive=1
Not working: 23" Display /boot/config.txt:
hdmi_cvt=1920 1200 60
hdmi_group=2
hdmi_mode=87
hdmi_drive=1
bigsur
by adafruit_support_mike on Thu Jun 27, 2019 11:14 pm
I haven't seen a mini-HDMI adapter issue that was related to display resolution, but we've seen the adapters themselves fail.
It sounds like you might have one with a bit of unexpected parasitic inductance or capacitance.. low enough for lower resolution signals to work, but high enough to cause problems when you start sending higer resolution data which needs a faster clock rate.
Let's try another one of those. Send a note containing a link to this page and your order number to support@adafruit.com. The folks there will get you one of these:
https://www.adafruit.com/product/2819
by bigsur on Fri Jul 05, 2019 3:11 pm
Thank you Mike. I just sent a message to the Zay :)
bigsur
