Larson Eye help
Larson Eye help
by mattielung on Fri Jun 14, 2019 11:22 am
I am attempting to create the Larson Eye.
I purchased the NeoPixel RGB 144 and the Gemma MO.
I also purchased the recommended circuit playground bolt on kit in hopes that I could avoid having the solder anything.
The pictures in the tutorial show 3 wires coming from the end of the Neopixel RGB being attached to the GEMMA MO.
The neopixal RGB has 4 wires coming from it. (See attachment)
2 of the wires, black and white have a plastic thingy (sorry I am new to the world of electronics) that I assume would be used to attache 2 neopixel strips together.
I think that I need to cut off the plastic attachment and use only the white wire and disregard the other black wire.
Can some one please let me know if this is the correct procedure?
I am really excited about getting this working!!!
Here is the link to the adafruit guide
https://learn.adafruit.com/larson-scanner-shades
mattielung
Re: Larson Eye help
by kcl1s on Fri Jun 14, 2019 2:06 pm
OK. Let see if we can get your project going.
You mention the Larson Eye, are you working from a tutorial? If so post a link.
Normally for a 144 pixel strip you would need an external 5 volt power supply. If you only ever run the Larson code you will only have a few pixels lit at a time and can get away with the USB or battery power. See the Neopixel guide more info https://learn.adafruit.com/adafruit-neopixel-uberguide
For wiring best to cut the connector off for your project (your attachment did not come through) the 2 blacks are GND. Just twist them together and connect to GND on the Gemma. The Red wire should go to Vout on the Gemma. The signal wire (white?, blue?) can go to any I/O pin on the Gemma. Adjust your code for that connection.
That should get you started. Ask questions or post photos using the File Upload below the edit window if you need more help.
Fellow hobbyist
Keith
kcl1s
Re: Larson Eye help
by mattielung on Fri Jun 14, 2019 2:20 pm
This is the tutorial I am working from.
I think you have answered my question.
Thanks for your help!!!!
Just in case, I am going to re-add the picture of what I bought to the original post. It was too big and I had to resize it.
mattielung
Re: Larson Eye help
by mattielung on Tue Jul 09, 2019 9:58 am
I am going to keep this post under the Larson eye help in case anyone else has the same issue.
I purchased;
Gemma MO
Adafruit NeoPixel Digital RGB LED Strip 144 LED
Bolt-On Kit for Circuit Playground,
The neopixel comes with braided wire and 2 black grounding wires.
I am having an issue using the bolt on kit. I cannot keep the wires from touching the other terminals. I can get it working, but if the wires get jiggled a tiny but, it shorts out.
I think the best option for me would to buy insulated ring crimp terminals.
I do not see anything like this listed on the adafruit website.
I think I need the 22-16 awg size connectors.
I am afraid to buy the wrong kind for fear of ruining the gemma mo.
Can anyone advise me on what size connector to buy?
mattielung
Re: Larson Eye help
by adafruit_support_mike on Tue Jul 09, 2019 9:14 pm
Ring terminals shouldn't do any harm to the Gemma. Just make sure they fit the wire, fit over the bolts, and don't touch more than one pad.
