USB slim connector overmold sliding off 1827
by Jamex on Tue Jul 23, 2019 5:07 pm
assembled, looks OK
usb slim assembled.PNG (417.71 KiB) Viewed 140 times
Hi I've been using these USB DIY Slim Connector Shell - A-M Plug for years but lately been having many of them where the cover (overmold) doesn't stay in place: it slides off without any resistance. Normally you press it into place as in the assembled pic then you can plug and unplug it from a USB A female socket. I have been getting many of them now where the overmold slides off if you try to remove it from a socket, or it slides off very easily with just bare fingers on the overmold and the exposed metal. Didn't do this in the past. I haven't changed the way I assemble them.
Any suggestions? Could this be a quality issue? Most recent Order Number is 2090392-5270819551, bought them 7/1/19. Pics attached
dissassembles way too easily, hood slides right off
usb slim fit disassembled.PNG (401.3 KiB) Viewed 140 times
Jamex
Re: USB slim connector overmold sliding off 1827
by adafruit_support_mike on Wed Jul 24, 2019 1:30 pm
Are you seeing the issue with new connectors that haven’t been used much, or with old connectors that have been used for a while?
by Jamex on Fri Jul 26, 2019 9:47 am
It happens with brand new connectors immediately after assembly: Many are loose enough that they slide right off with very little resistance, and most come off the first time removing the connector from a female USB socket. I buy these in large quantities, and I've experimented with how far to press the cover onto the metal: I can press the cover on as far as a normal commercial overmold, or farther, with the same results. I've bought over 1700 of these since 2014, usually 100 pcs at a time since, and they've been working fine until order # 2021089-1621039965 received in April 2019.
Jamex
by adafruit_support_mike on Sat Jul 27, 2019 12:20 am
Thank you. I'll have someone check the ones we have in stock and see if we can duplicate the problem.
by adafruit2 on Mon Jul 29, 2019 4:37 pm
hiya all our stock is the same, looks like the molding changed a bit. All we can recommend for now is a dab of glue to keep the housing on while we try to get old-style ones back in stock (no ETA)
adafruit2
Site Admin
by Jamex on Mon Jul 29, 2019 4:58 pm
OK, thank you for the response. Understanding there is no ETA, is there a way for you to notify me when/if you get the old-style ones back in stock?
Jamex
by adafruit2 on Mon Jul 29, 2019 5:10 pm
we will post here!
adafruit2
Site Admin
