underwater sensing
underwater sensing
by pret5097 on Mon Jul 29, 2019 7:57 am
Hello
Have certain project idea that involves listening to underwater pressure changes/waves. Sounds like listening to a mechanical waves that propagate through the water, so I guess need a microphone that would be suitable for underwater/submerged operation and sensitive in the low frequencies range
Any hints as to what kind of microphone that can be ? Or probably other kind of sensors are more suitable for the task ?
pret5097
Re: underwater sensing
by adafruit_support_mike on Tue Jul 30, 2019 2:03 pm
What’s your frequency range of interest?
A microphone is a good choice as long as the signals you want are above about 20Hz. Below that it’s usually easier to use a speaker as the input device, and connect it to a low-impedance/high-gain amplifier. The classical solution is to use the speaker coil to drive a BJT amplifier with lots of current gain.
by millercommamatt on Tue Jul 30, 2019 5:15 pm
Maybe you can by a hydrophone and DIY the rest. I don't know how you buy from these folks, but I do know their HTI-96 is used in sound traps by marine scientists: http://www.hightechincusa.com/products/hydrophones/
millercommamatt
