OLED display not working with Ultimate GPS
by Squiddles1227 on Mon Jul 29, 2019 6:41 pm
I've been trying to read data from a GPS and then display it on a Monochrome 0.96" 128x64 OLED graphic display. Everything works fine until I uncomment the three lines of code that send commands to the GPS. The screen will not light up at all. Any help or suggestions would be greatly appreciated.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_MOSI   9
#define OLED_CLK   10
#define OLED_DC    11
#define OLED_CS    12
#define OLED_RESET 13
#define GPS_RX 7
#define GPS_TX 8
#define GPSECHO  true
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
SoftwareSerial mySerial(GPS_TX, GPS_RX);
Adafruit_GPS GPS(&mySerial);
boolean usingInterrupt = false;
void useInterrupt(boolean);
uint32_t timer = millis();
short tzOffset = 4;
static const unsigned char PROGMEM waveWithName[]  = {
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xfd, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xe0, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3c, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x0c, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x00, 0x00, 0x3f, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x61, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0xc0, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00,
  0x00, 0x40, 0x00, 0x01, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x0f, 0xff, 0xf8, 0x00,
  0x00, 0x20, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x07, 0xff, 0x80, 0x00, 0x00,
  0x00, 0x18, 0x00, 0x7c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xff, 0xff, 0x80, 0x00, 0x00, 0x00,
  0x00, 0x07, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x0e, 0x00, 0x00, 0x00, 0x00, 0x84, 0x00, 0x04, 0x00, 0x40, 0x00, 0x7e, 0x02, 0x00, 0x04, 0x10,
  0x1b, 0x00, 0x00, 0x10, 0x00, 0x84, 0x00, 0x04, 0x00, 0x40, 0x00, 0x04, 0x02, 0x00, 0x04, 0x00,
  0x10, 0x38, 0xc7, 0x38, 0xc3, 0x87, 0x22, 0x04, 0xe1, 0xc6, 0x38, 0x0c, 0xe2, 0x30, 0xe4, 0x90,
  0x10, 0x21, 0x20, 0x91, 0x24, 0x84, 0x96, 0x04, 0x12, 0x49, 0x24, 0x18, 0x12, 0x49, 0x05, 0x10,
  0x10, 0x21, 0xe7, 0x91, 0xe4, 0x84, 0x94, 0x04, 0xf2, 0x4f, 0x24, 0x10, 0xf2, 0x78, 0xc7, 0x10,
  0x10, 0x21, 0x04, 0x91, 0x04, 0x84, 0x94, 0x04, 0x92, 0x48, 0x24, 0x30, 0x92, 0x40, 0x27, 0x10,
  0x1b, 0x21, 0x24, 0x91, 0x24, 0x84, 0x88, 0x0c, 0x92, 0x49, 0x24, 0x20, 0x92, 0x48, 0x25, 0x90,
  0x0e, 0x20, 0xc7, 0x98, 0xc3, 0x87, 0x08, 0x78, 0xf1, 0xc6, 0x24, 0x7e, 0xf1, 0x31, 0xc4, 0xd0,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  display.begin(SSD1306_SWITCHCAPVCC);
  startScreen();
  GPS.begin(9600);
//  GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA); // these three lines are the problem
//  GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);
//  GPS.sendCommand(PGCMD_ANTENNA);
  useInterrupt(true);
  delay(1000);
SIGNAL(TIMER0_COMPA_vect) {
    char c = GPS.read();
#ifdef UDR0
    if (GPSECHO)
        if (c) UDR0 = c;
#endif
void useInterrupt(boolean v) {
    if (v) {
        OCR0A = 0xAF;
        TIMSK0 |= _BV(OCIE0A);
        usingInterrupt = true;
    else {
        TIMSK0 &= ~_BV(OCIE0A);
void startScreen() {
  display.clearDisplay();
  display.drawBitmap(0, 0, waveWithName, 128, 64, WHITE);
  display.display();
  delay(3000);
  for(int16_t i=0; i<display.height()/2; i+=1) {
    display.drawRect(i, i, display.width()-2*i, display.height()-2*i, WHITE);
    display.display();
    delay(2);
void printDateTime() {
    short hr = GPS.hour - tzOffset;
    if (hr < 0)
        hr += 24;
    if (hr  < 10)
        display.print('0');
    display.print(hr, DEC);
    display.print(':');
    if ((short)GPS.minute < 10)
        display.print('0');
    display.print(GPS.minute, DEC);
    display.print(':');
    if ((short)GPS.seconds < 10)
        display.print('0');
    display.print(GPS.seconds, DEC);
void printHeading() {
    char dir[3];
    dir[0] = ' ';
    dir[1] = ' ';
    dir[2] = ' ';
    if (GPS.angle > 337.25)
        dir[0] = 'N';
    else if (GPS.angle <= 22.5)
        dir[0] = 'N';
    else if (GPS.angle <= 67.5)
        dir[0] = 'N';
        dir[1] = 'E';
    else if (GPS.angle <= 112.5)
        dir[0] = 'E';
    else if (GPS.angle <= 157.5)
        dir[0] = 'S';
        dir[1] = 'E';
    else if (GPS.angle <= 202.5)
        dir[0] = 'S';
    else if (GPS.angle <= 247.5)
        dir[0] = 'S';
        dir[1] = 'W';
    else if (GPS.angle <= 292.5)
        dir[0] = 'W';
    else if (GPS.angle <= 337.5)
        dir[0] = 'N';
        dir[1] = 'W';
    display.print(dir[0]);
    display.print(dir[1]);
    display.print(dir[2]);
void updateDisplay() {
    display.setTextColor(WHITE);
    display.setCursor(0, 0);
    display.setTextSize(2);
    printDateTime();
    display.setTextSize(0);
    display.setCursor(110, 0);
    display.print((int)GPS.satellites);
    if (GPS.fix)
        display.setCursor(110, 8);
        display.print(GPS.HDOP, 1);
        display.print(GPS.latitudeDegrees, 5); display.print(','); display.println(GPS.longitudeDegrees, 5);
        display.print(GPS.altitude, 0); display.print("m ");
        if ((int)GPS.speed>0)
            printHeading();
        else
           display.print("-- ");
        // speed is in knots, convert to mph
        display.print((int)(GPS.speed*1.15078)); display.println(" mph");
    display.display();
void loop()
    if (GPS.newNMEAreceived()) {
        if (!GPS.parse(GPS.lastNMEA()))
            return;
    if (timer > millis())  timer = millis();
    if (millis() - timer > 1000) {
        timer = millis(); // reset the timer
        updateDisplay();
Squiddles1227
Re: OLED display not working with Ultimate GPS
by adafruit_support_carter on Mon Jul 29, 2019 7:17 pm
Seems odd, esp. since you call startScreen() first and it has a 3 second delay. You don't even see the 'waveWithName' bitmap?
by Squiddles1227 on Mon Jul 29, 2019 7:27 pm
No, the screen never turns on.
Squiddles1227
by adafruit_support_carter on Mon Jul 29, 2019 7:42 pm
Try adding some serial prints to verify the code is tracing through as expected. Ex:
      Serial.println("startScreen - clear");
      display.display();
      Serial.println("startScreen - 3 second delay");
      delay(3000);
      Serial.println("startScreen - loop");
        display.display();
        delay(2);
Be sure to do the typical serial init stuff in setup(). And post what you get in the serial monitor.
by Squiddles1227 on Mon Jul 29, 2019 8:05 pm
Heres the code:
#include <SPI.h>
#include <Wire.h>
#define OLED_MOSI   9
#define OLED_CLK   10
#define OLED_DC    11
#define OLED_CS    12
#define GPS_RX 7
#define GPS_TX 8
short tzOffset = 4;
  Serial.begin(9600);
  startScreen();
  GPS.begin(9600);
  useInterrupt(true);
  delay(1000);
#ifdef UDR0
    if (GPSECHO)
        if (c) UDR0 = c;
#endif
    if (v) {
        OCR0A = 0xAF;
    else {
  display.display();
  delay(3000);
    display.display();
    delay(2);
    if (hr < 0)
        hr += 24;
    if (hr  < 10)
        display.print('0');
    display.print(':');
        display.print('0');
    display.print(':');
        display.print('0');
    char dir[3];
    dir[0] = ' ';
    dir[1] = ' ';
    dir[2] = ' ';
        dir[0] = 'N';
        dir[0] = 'N';
        dir[0] = 'N';
        dir[1] = 'E';
        dir[0] = 'E';
        dir[0] = 'S';
        dir[1] = 'E';
        dir[0] = 'S';
        dir[0] = 'S';
        dir[1] = 'W';
        dir[0] = 'W';
        dir[0] = 'N';
        dir[1] = 'W';
    printDateTime();
    if (GPS.fix)
            printHeading();
        else
    display.display();
void loop()
            return;
        updateDisplay();
And here's what the serial reads:
ststartScreen - 3 second delay
Every three seconds a new line pops up.
Squiddles1227
by adafruit_support_carter on Mon Jul 29, 2019 8:17 pm
I'd suspect something with the interrupt, but in theory you haven't even turned it on at that point in the code. And it stays commented in with the version that works.
What are you using as the host controller? UNO?
by Squiddles1227 on Mon Jul 29, 2019 8:30 pm
Yes, Uno.
Squiddles1227
by adafruit_support_carter on Tue Jul 30, 2019 12:58 pm
Try without interrupts.
#include <SPI.h>
#include <Wire.h>
#define OLED_MOSI   9
#define OLED_CLK   10
#define OLED_DC    11
#define OLED_CS    12
#define GPS_RX 7
#define GPS_TX 8
//void useInterrupt(boolean);
short tzOffset = 4;
  Serial.begin(9600);
  startScreen();
  GPS.begin(9600);
//  useInterrupt(true);
  delay(1000);
//SIGNAL(TIMER0_COMPA_vect) {
//    char c = GPS.read();
//#ifdef UDR0
//    if (GPSECHO)
//        if (c) UDR0 = c;
//#endif
//void useInterrupt(boolean v) {
//    if (v) {
//        OCR0A = 0xAF;
//        TIMSK0 |= _BV(OCIE0A);
//        usingInterrupt = true;
//    else {
//        TIMSK0 &= ~_BV(OCIE0A);
//        usingInterrupt = false;
  display.display();
  delay(3000);
    display.display();
    delay(2);
    if (hr < 0)
        hr += 24;
    if (hr  < 10)
        display.print('0');
    display.print(':');
        display.print('0');
    display.print(':');
        display.print('0');
    char dir[3];
    dir[0] = ' ';
    dir[1] = ' ';
    dir[2] = ' ';
        dir[0] = 'N';
        dir[0] = 'N';
        dir[0] = 'N';
        dir[1] = 'E';
        dir[0] = 'E';
        dir[0] = 'S';
        dir[1] = 'E';
        dir[0] = 'S';
        dir[0] = 'S';
        dir[1] = 'W';
        dir[0] = 'W';
        dir[0] = 'N';
        dir[1] = 'W';
    printDateTime();
    if (GPS.fix)
            printHeading();
        else
    display.display();
void loop()
            return;
        updateDisplay();
by Squiddles1227 on Tue Jul 30, 2019 11:40 pm
The code uploads correctly but seems to have no effect on the screen at all. The screen is still black.
Squiddles1227
