MEMS Microphone Breakout - SPW2430
by Sarah2019 on Tue Jul 30, 2019 5:18 pm
I want to record sound by "Adafruit Silicon MEMS Microphone Breakout - SPW2430".
Just I tap on the sensor and record the detected signal.
What electronics do I need to use? I have a DC power-supply, oscilloscope, what else do I need?
Thanks for your help at this matter.
Sarah
Sarah2019
Re: MEMS Microphone Breakout - SPW2430
by adafruit_support_mike on Wed Jul 31, 2019 2:17 pm
What kind of recorded output do you want.. raw data, WAV files, or some other audio format?
The hardware you’ll need depends on the result you want.
by Sarah2019 on Wed Jul 31, 2019 4:36 pm
I want just audio, I’ll take FFT of that.
Sarah2019
by adafruit_support_mike on Fri Aug 02, 2019 12:00 am
If you want to do FFTs, you'll need digitized audio sampled at least twice as fast as the highest frequency of interest.
Doing that by hand with a RasPi is fairly complicated, because Linux is a time-slicing OS. It gives each program about 10ms on a CPU, then suspends it to give the next program a turn. That's okay for human-speed things like typing and using a mouse, but causes significant problems when you get down into the millisecond and microsecond range. Anything that needs real-time stability has to be handled with a kernel module.
You can save a lot of effort by using an I2S mic:
https://www.adafruit.com/product/3421
That does the analog-to-digital conversion internally, and there's already a kernel module to transfer the data to the RasPi.
