Adafruit 0.56" 4-Digit 7-Segment Display with/I2C Backpack h
by uiaad on Wed Jul 31, 2019 11:42 pm
I will try and be as brief as possible, but I bought Adafruit 0.56" 4-Digit 7-Segment Display with/I2C Backpack and NodeMcu ESP8266 to create a youtube subscriber counter ( https://www.instructables.com/id/YouTube-Subscriber-Counter-With-ESP8266-V2/ ). Everything came, soldered up the backpacks programed the Node, hooked everything up and nothing. I mean the Node will output to serial monitor but nothing to the displays.
I then decided to test out each display one by one and opened up the Seven segment time display example as included with one of the adafruit libraries hooked, programmed the Node once more and hooked up the connections and still nothing. Tested both the displays and I have no idea why its not working.
If any one has any ideas i would be very very greatful :)
uiaad
Re: Adafruit 0.56" 4-Digit 7-Segment Display with/I2C Backpa
by franklin97355 on Thu Aug 01, 2019 12:04 am
Post a picture of the display and the soldering. Do you have any other processors you could test the display with?
franklin97355
by uiaad on Thu Aug 01, 2019 12:25 am
Hi, thanks for the reply, please see pics below. I have also tried this with and a Arduino Mega and Wemos Mini D1, at this point i have no idea what i could possibly be doing wrong
uiaad
by uiaad on Fri Aug 02, 2019 7:16 pm
Anyone ?
uiaad
by AKGuide on Sun Dec 01, 2019 3:03 am
Did you run the ic2 scanner on the displays w/backpacks?
https://playground.arduino.cc/Main/sour ... lock&num=1
I am curious as I have three .56 4 digit seven segment displays w/backpacks with the exact same issue and I know my program is working as I can hook up different 1.2" displays using a backpack and get those to work with the test program
The scanner when on mine, (the .56" displays) however, is not finding an ic2 address on any of that size backpacks... so wondering if you have the same issue.
AKGuide
