faulty neopixel ring?
by mark_r_jarrod on Sun Aug 04, 2019 3:21 pm
i have purchased a neopixel 24 led ring and i find i can only get 1 led to work, using a 16 pixel ring with no changes to code works fine (obs 16 pixel as apposed to 24), i have soldered the connections to the 24 led ring and double checked for damage to circuit , poor joints etc but cannot find anything
would this indicate a faulty ring, or a mess up on my part code wise?
i borrowed the code superhero power plant code by tony sherwood for testing ,only changed the number of led's to 24 and pin assignment to 9
added pics so you see what i mean
mark_r_jarrod
Re: faulty neopixel ring?
by adafruit_support_mike on Sun Aug 04, 2019 4:53 pm
As a test, try jumping the data output from the pixel that works to the data-in pin of the third pixel (jump over the first one that doesn’t work). That can give us more information about the nature of the problem.
by mark_r_jarrod on Mon Aug 05, 2019 12:34 pm
hi , did as suggested, all other leds lit up bar 1, seems like 2nd led may have dead driver chip
mark_r_jarrod
by adafruit_support_mike on Tue Aug 06, 2019 8:14 pm
Yep. When did you get the NeoPixel ring?
by mark_r_jarrod on Wed Aug 07, 2019 2:55 am
Only got it a week or so ago
mark_r_jarrod
by adafruit_support_mike on Fri Aug 09, 2019 11:07 pm
Thanks. Send a note containing a link to this page and your order number to support@adafruit.com. The folks there will get you a replacement ring.
by mark_r_jarrod on Sat Aug 10, 2019 9:11 am
many thanks guys
mark_r_jarrod
