AHRS Bluefruit App Crashing
by jzelina on Wed Aug 07, 2019 8:47 am
I am working on a project using a Feather M0 Bluefruit LE and a NXP 9-DOF w/ FXOS8700 + FXAS21002 (Product ID 3463) array to get data in Quaternions to my phone. I am using the ahrs_fusion_ble_nrf51 example sketch and have followed the tutorials for configuring the code to my Feather. I am connecting to an up to date IPhone 7.
When I attempt to view the sensor data on the Bluefruit App under the "3D Visualization" button, the app crashes and loses connection with the board. Sometimes it connects and shows good data for a couple seconds before crashing. At the same time, I can see that I'm getting good sensor data on my Serial Monitor on the computer. I can also run other ble example sketches with no issues, such as the "atcommand" sketch.
Does anyone have any thoughts as to why my app is crashing like this? I am new to this but for lack of more intelligent terms, am I trying to send too much information too quickly? My code is attached below. Any help would be greatly appreciated!
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include <Mahony.h>
#include <Madgwick.h>
#include <Adafruit_BLE.h>
#include <Adafruit_BluefruitLE_SPI.h>
#include <Adafruit_BluefruitLE_UART.h>
#include "BluefruitConfig.h"
// Note: This sketch is a WORK IN PROGRESS
#define BLUEFRUIT51_ST_LSM303DLHC_L3GD20        (0)
#define BLUEFRUIT51_ST_LSM9DS1                  (1)
#define BLUEFRUIT51_NXP_FXOS8700_FXAS21002      (2)
// Define your target sensor(s) here based on the list above!
// #define AHRS_VARIANT    BLUEFRUIT51_ST_LSM303DLHC_L3GD20
#define AHRS_VARIANT   BLUEFRUIT51_NXP_FXOS8700_FXAS21002
// Config
#define FACTORYRESET_ENABLE      1
#if AHRS_VARIANT == BLUEFRUIT51_ST_LSM303DLHC_L3GD20
#include <Adafruit_L3GD20_U.h>
#include <Adafruit_LSM303_U.h>
#elif AHRS_VARIANT == BLUEFRUIT51_ST_LSM9DS1
// ToDo!
#elif AHRS_VARIANT == BLUEFRUIT51_NXP_FXOS8700_FXAS21002
#include <Adafruit_FXAS21002C.h>
#include <Adafruit_FXOS8700.h>
#else
#error "AHRS_VARIANT undefined! Please select a target sensor combination!"
#endif
// Create sensor instances.
Adafruit_L3GD20_Unified       gyro(20);
Adafruit_LSM303_Accel_Unified accel(30301);
Adafruit_LSM303_Mag_Unified   mag(30302);
// ToDo!
Adafruit_FXAS21002C gyro = Adafruit_FXAS21002C(0x0021002C);
Adafruit_FXOS8700 accelmag = Adafruit_FXOS8700(0x8700A, 0x8700B);
#endif
// Bluetooth
// ...hardware SPI, using SCK/MOSI/MISO hardware SPI pins and then user selected CS/IRQ/RST
Adafruit_BluefruitLE_SPI ble(BLUEFRUIT_SPI_CS, BLUEFRUIT_SPI_IRQ, BLUEFRUIT_SPI_RST);
// Mag calibration values are calculated via ahrs_calibration.
// These values must be determined for each baord/environment.
// See the image in this sketch folder for the values used
// below.
// Offsets applied to raw x/y/z mag values
float mag_offsets[3]            = { 54.32F, 63.94F, 81.77F };
// Soft iron error compensation matrix
float mag_softiron_matrix[3][3] = { {  0.975,  -0.022,  0.005 },
                                    {  -0.022,  0.975,  0.001 },
                                    {  0.005,  0.001,  1.053 } };
float mag_field_strength        = 48.46F;
// Offsets applied to compensate for gyro zero-drift error for x/y/z
// Raw values converted to rad/s based on 250dps sensitiviy (1 lsb = 0.00875 rad/s)
/*float rawToDPS = 0.00875F;
float dpsToRad = 0.017453293F;
float gyro_zero_offsets[3]      = { 175.0F * rawToDPS * dpsToRad,
                                   -729.0F * rawToDPS * dpsToRad,
                                    101.0F * rawToDPS * dpsToRad };
//Offsets from USB Code
float gyro_zero_offsets[3]      = { 0.0F, 0.0F, 0.0F };
// Mahony is lighter weight as a filter and should be used
// on slower systems
Mahony filter;
//Madgwick filter;
void setup()
  Serial.begin(115200);
  // Wait for the Serial Monitor to open (comment out to run without Serial Monitor)
  //while(!Serial);
  Serial.println(F("Adafruit AHRS BLE Fusion Example")); Serial.println("");
  // Initialize the sensors.
  if(!gyro.begin())
    /* There was a problem detecting the gyro ... check your connections */
    Serial.println("Ooops, no gyro detected ... Check your wiring!");
    while(1);
#if AHRS_VARIANT == BLUEFRUIT51_NXP_FXOS8700_FXAS21002
  if(!accelmag.begin(ACCEL_RANGE_4G))
    Serial.println("Ooops, no FXOS8700 detected ... Check your wiring!");
    while(1);
#else
  if (!accel.begin())
    /* There was a problem detecting the accel ... check your connections */
    Serial.println("Ooops, no accel detected ... Check your wiring!");
    while (1);
  if (!mag.begin())
    /* There was a problem detecting the mag ... check your connections */
    Serial.println("Ooops, no mag detected ... Check your wiring!");
    while (1);
#endif
  // Filter expects 25 samples per second
  // The filter only seems to be responsive with a much smaller value, though!
  // ToDo: Figure out the disparity between actual refresh rate and the value
  // provided here!
  filter.begin(10);
    // Initialise the module
  Serial.print(F("Initialising the Bluefruit LE module: "));
  if ( !ble.begin(VERBOSE_MODE) )
    Serial.println(F("Couldn't find Bluefruit, make sure it's in CoMmanD mode & check wiring?"));
  Serial.println( F("OK!") );
  // Factory Reset
  if ( FACTORYRESET_ENABLE )
    /* Perform a factory reset to make sure everything is in a known state */
    Serial.println(F("Performing a factory reset: "));
    if ( ! ble.factoryReset() ) {
      Serial.println(F("Couldn't factory reset"));
  /* Disable command echo from Bluefruit */
  ble.echo(false);
  Serial.println("Requesting Bluefruit info:");
  /* Print Bluefruit information */
  ble.info();
  /* Wait for a connection before starting the test */
  Serial.println("Waiting for a BLE connection to continue ...");
  ble.verbose(false);  // debug info is a little annoying after this point!
  // Wait for the connection to complete
  delay(1000);
  Serial.println(F("CONNECTED!"));
  Serial.println(F("**********"));
  // Set module to DATA mode
  Serial.println( F("Switching to DATA mode!") );
  ble.setMode(BLUEFRUIT_MODE_DATA);
  Serial.println(F("******************************"));
void loop(void)
  sensors_event_t gyro_event;
  sensors_event_t accel_event;
  sensors_event_t mag_event;
  while ( ble.isConnected() ) {
    // Get new data samples
    gyro.getEvent(&gyro_event);
    accelmag.getEvent(&accel_event, &mag_event);
#else
    accel.getEvent(&accel_event);
    mag.getEvent(&mag_event);
#endif
    // Apply mag offset compensation (base values in uTesla)
    float x = mag_event.magnetic.x - mag_offsets[0];
    float y = mag_event.magnetic.y - mag_offsets[1];
    float z = mag_event.magnetic.z - mag_offsets[2];
    // Apply mag soft iron error compensation
    float mx = x * mag_softiron_matrix[0][0] + y * mag_softiron_matrix[0][1] + z * mag_softiron_matrix[0][2];
    float my = x * mag_softiron_matrix[1][0] + y * mag_softiron_matrix[1][1] + z * mag_softiron_matrix[1][2];
    float mz = x * mag_softiron_matrix[2][0] + y * mag_softiron_matrix[2][1] + z * mag_softiron_matrix[2][2];
    // Apply gyro zero-rate error compensation
    float gx = gyro_event.gyro.x - gyro_zero_offsets[0];
    float gy = gyro_event.gyro.y - gyro_zero_offsets[1];
    float gz = gyro_event.gyro.z - gyro_zero_offsets[2];
    // The filter library expects gyro data in degrees/s, but adafruit sensor
    // uses rad/s so we need to convert them first (or adapt the filter lib
    // where they are being converted)
    gx *= 57.2958F;
    gy *= 57.2958F;
    gz *= 57.2958F;
    // Update the filter
    filter.update(gx, gy, gz,
                  accel_event.acceleration.x, accel_event.acceleration.y, accel_event.acceleration.z,
                  mx, my, mz);
    // Print the orientation filter output
    float roll = filter.getRoll();
    float pitch = filter.getPitch();
    float heading = filter.getYaw();
    Serial.print(millis());
    Serial.print(" - Orientation: ");
    Serial.print(pitch);
    Serial.print(" ");
    Serial.print(heading);
    Serial.print(" ");
    Serial.println(roll);
    // Send sensor data to Bluetooth
    char prefix[] = "V";
    ble.write(prefix, strlen(prefix));
    ble.write((uint8_t *)&pitch, sizeof(float));
    ble.write((uint8_t *)&heading, sizeof(float));
    ble.write((uint8_t *)&roll, sizeof(float));
    // Print the orientation filter output in quaternions.
    // This avoids the gimbal lock problem with Euler angles when you get
    // close to 180 degrees (causing the model to rotate or flip, etc.)
    float qw, qx, qy, qz;
    filter.getQuaternion(&qw, &qx, &qy, &qz);
    Serial.print(" - Quat: ");
    Serial.print(qw);
    Serial.print(" ");
    Serial.print(qx);
    Serial.print(" ");
    Serial.print(qy);
    Serial.print(" ");
    Serial.println(qz);
    ble.write((uint8_t *)&qw, sizeof(float));
    ble.write((uint8_t *)&qx, sizeof(float));
    ble.write((uint8_t *)&qy, sizeof(float));
    ble.write((uint8_t *)&qz, sizeof(float));
    delay(10);
jzelina
