Wiring Adafruit OLED to Pi Zero W problem
by m1lkyj0e on Thu Aug 08, 2019 10:09 am
I can't seem to get my OLED display to work (black screen) with my Raspberry Pi Zero W.
I don't know if it's a wiring issue or duff device. When I run the command 'i2cdetect -y 1', the device does not show up!? I (think) I'm setting it up in SPI mode and have followed various guides online, but to no avail.
I'm trying to follow this: https://learn.adafruit.com/monochrome-o ... 8x64-oleds and http://www.raspberrypirobotics.com/inte ... pberry-pi/
Do I need to connect all the jumper cables on the top and bottom rows, and are all raspberry pi GPIO pins numbered the same?
I don't really know what I'm doing, lol.
Thanks.
My current setup.
m1lkyj0e
Re: Wiring Adafruit OLED to Pi Zero W problem
by franklin97355 on Thu Aug 08, 2019 7:52 pm
Can we see closeups of both sides of the display?
franklin97355
by m1lkyj0e on Fri Aug 09, 2019 4:51 pm
Now showing this
pi@raspberrypi:~ $ sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- 3d -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
I'm now getting this error...
File "/usr/local/bin/lcd-show.py", line 47, in <module>
disp.begin()
File "/usr/local/lib/python2.7/dist-packages/Adafruit_SSD1306/SSD1306.py", line 148, in begin
self._initialize()
File "/usr/local/lib/python2.7/dist-packages/Adafruit_SSD1306/SSD1306.py", line 247, in _initialize
self.command(SSD1306_DISPLAYOFF) # 0xAE
File "/usr/local/lib/python2.7/dist-packages/Adafruit_SSD1306/SSD1306.py", line 129, in command
self._i2c.write8(control, c)
File "build/bdist.linux-armv6l/egg/Adafruit_GPIO/I2C.py", line 116, in write8
File "build/bdist.linux-armv6l/egg/Adafruit_PureIO/smbus.py", line 256, in write_byte_data
IOError: [Errno 121] Remote I/O error
m1lkyj0e
