PowerBoost 500 Charger backfeeding
by JUehV on Wed Aug 14, 2019 7:19 am
I'm powering my mobile Raspberry Pi Zero with a PowerBoost 500 Charger. So now I'm wondering if it is an issue when the Pi gets power from its USB ports (because I want to use it in gadged mode sometimes). I worry in a worst case current would flow back in the board and damage something. Or is there already an protection ?
Cheers!
JUehV
Re: PowerBoost 500 Charger backfeeding
by adafruit_support_bill on Wed Aug 14, 2019 7:25 am
The output pin of the boost converter is rated to tolerate up to 7v (Absolute Maximum rating). Though it is not a recommended operating condition, it should be OK. You could add a diode on the 5v line between the Boost and the Pi for best protection.
by JUehV on Wed Aug 14, 2019 7:40 am
Thanks you so much for that fast answer!
adafruit_support_bill wrote:You could add a diode on the 5v line between the Boost and the Pi for best protection.
I thought about a diode too. But with the high power consumption of the Pi, the small voltage drop of the diode results in a non-negligible power loss :/
JUehV
