Raspian Buster Compatibility
by wsquared58 on Mon Aug 19, 2019 8:53 am
I decided to start over with my project and as part of that I reformatted SD card and rather than using NOOBS as starting point I loaded Raspian from the provided link. No apparent problems so far but want to understand a few things.
Raspian Buster is what got installed and as part of automated install process it asked if I wanted to check for updates which I answered yes but then came back with a message about it being a pre-release or something to that effect and updates would not be available until after a certain date. Just wondering what that was all about.
Subsequently updated via terminal window.
Also all of the various breakout sensors will have no issues?
wsquared58
Re: Raspian Buster Compatibility
by adafruit_support_carter on Mon Aug 19, 2019 1:27 pm
Sounds like you are running into this?
https://www.raspberrypi.org/forums/view ... p?t=245073
I've had that happen also. Quick fix is:
sudo apt update
and say yes at prompt.
