Adafruit sound board headache
Re: Adafruit sound board headache
by Proteus1985 on Wed Aug 21, 2019 12:41 pm
A
Proteus1985
by Proteus1985 on Wed Aug 21, 2019 12:43 pm
Finally
Proteus1985
by adafruit_support_carter on Wed Aug 21, 2019 2:00 pm
Try turning off "hide file extensions" in Windows and check again what is shown. There have been some issues with that "feature" of Windows hiding the full filename and adding confusion.
by Proteus1985 on Wed Aug 21, 2019 4:35 pm
With file extensions
Proteus1985
by Proteus1985 on Thu Aug 22, 2019 11:18 am
So can I assume this is a faulty board?
Proteus1985
by adafruit_support_carter on Thu Aug 22, 2019 12:53 pm
It could be soldering. Let's go back to that.
Several of your pins look cold soldered with inadequate wetting out. See here:
https://learn.adafruit.com/adafruit-gui ... n-problems
The power pins seem to be good enough to get the power LED to come on, but worth touching up. More importantly, make sure the trigger pins are good. The G pin looks also not wetted out enough, so would prevent any pin from triggering.
Try reflowing those pins and see if that helps.
by Proteus1985 on Wed Aug 28, 2019 1:04 pm
So I’ve brought a new board, solder it up real good, and same problem, nothing happening. Beyond frustrated, can’t believe 2 board ain’t working
Proteus1985
by Proteus1985 on Wed Aug 28, 2019 1:07 pm
Here’s the new board
Proteus1985
by adafruit_support_carter on Wed Aug 28, 2019 1:29 pm
It still looks like it could be soldering. The trigger ground (G) pin looks cold soldered. And some of the trigger pins look a bit thin. Power is much more forgiving than signals in terms of soldering. So the solder on your power pins is good enough to get the green PWR LED to come on.
What are you currently using for battery power? Sounds like you tried a few things. The general recommendations are here:
https://learn.adafruit.com/adafruit-aud ... d-pins-5-5
by Proteus1985 on Wed Aug 28, 2019 1:33 pm
I’m using 2 as batterys to power the board.
I’m off down the shop to buy a new soldering iron....
Proteus1985
by adafruit_support_carter on Wed Aug 28, 2019 1:48 pm
Try also going back to the 3x battery supply you mentioned. That's the general recommendation for the board:
We recommend 3xAA or 3xAAA alkaline or rechargeable as ideal. You can use 4xAA or 4xAAA but in that case, make sure you've got rechargeable batteries, as the higher voltage alkalines may be a bit much for the board.
by Proteus1985 on Wed Aug 28, 2019 2:49 pm
SOLVED! 3AA batterys was the solution
Proteus1985
by adafruit_support_carter on Thu Aug 29, 2019 12:13 pm
Yeah! And both boards are good now?
by Proteus1985 on Thu Aug 29, 2019 12:35 pm
Lol, yes, both boards work fine now - facepalm myself, I’m using rechargeable AA’s which of course only supply 1.2v each........ when using 2 obviously your not getting your minimum 3v supply, felt like such an idiot when I realised lol but thank you for all the help
Proteus1985
by adafruit_support_carter on Thu Aug 29, 2019 12:42 pm
Cool. Just glad they are all working now. Have fun!
