nRF52 Feather and LIS3DH
by RRB on Wed Aug 21, 2019 4:51 pm
Hi, I am trying to run an LIS3DH accelerometer example program (Acceldemo) using the nRF52 Bluefruit feather. I have been successful running the same program using I2C or SPI with an ESP32 feather but not with the Bluefruit. I have been successful running a number BLE example programs on the nRF52. After the Acceldemo program is loaded to the nRF52 the LEDs go dark and not even the first Serial.println in Setup executes. I am assuming there must be a lot of things missing in the nRF52 but wanted to check if Adafruit believes this should work and that therefore there is something wrong in my use of the board either in pin assignments, wiring, or something else. I really appreciate your support and direction.
RRB
Re: nRF52 Feather and LIS3DH
by adafruit_support_mike on Thu Aug 22, 2019 2:26 am
Post a photo showing your hardware and connections, and post the code you're having trouble with between CODE tags please.
800x600 images usually work best.
by RRB on Sat Aug 24, 2019 4:24 pm
Wiring of Adafruit BlueFruit 52 and LIS3DH
// Basic demo for accelerometer readings from Adafruit LIS3DH
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_LIS3DH.h>
#include <Adafruit_Sensor.h>
// Used for software SPI
//#define LIS3DH_CLK 13
//#define LIS3DH_MISO 12
//#define LIS3DH_MOSI 11
// Used for hardware & software SPI
// #define LIS3DH_CS 7
// software SPI
//Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS, LIS3DH_MOSI, LIS3DH_MISO, LIS3DH_CLK);
// hardware SPI
// Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS);
// I2C
Adafruit_LIS3DH lis = Adafruit_LIS3DH();
#ifndef ESP8266
  while (!Serial);     // will pause Zero, Leonardo, etc until serial console opens
#endif
  Serial.begin(115200);
  Serial.println("LIS3DH test!");
  if (! lis.begin(0x18)) {   // change this to 0x19 for alternative i2c address
    Serial.println("Couldnt start");
    while (1);
  Serial.println("LIS3DH found!");
  lis.setRange(LIS3DH_RANGE_8_G);   // 2, 4, 8 or 16 G!
  Serial.print("Range = "); Serial.print(2 << lis.getRange());
  Serial.println("G");
  lis.read();      // get X Y and Z data at once
  // Then print out the raw data
  Serial.print("X:  "); Serial.print(lis.x);
  Serial.print("  \tY:  "); Serial.print(lis.y);
  Serial.print("  \tZ:  "); Serial.print(lis.z);
  /* Or....get a new sensor event, normalized */
  sensors_event_t event;
  lis.getEvent(&event);
  /* Display the results (acceleration is measured in m/s^2) */
  Serial.print("\t\tX: "); Serial.print(event.acceleration.x);
  Serial.print(" \tY: "); Serial.print(event.acceleration.y);
  Serial.print(" \tZ: "); Serial.print(event.acceleration.z);
  Serial.println(" m/s^2 ");
  Serial.println();
  delay(200);
Posted the picture of wiring and the example acceldemo program, configured for I2C. The same code worked on ESP32 breakout board when compiled with ESB32 as target. When compiling for the Bluefruit the setup is shown attached file.
Arduino IDE configuration when compiling for Bluefruit52
Screen Shot 2019-08-24 at 4.16.22 PM.png (128.32 KiB) Viewed 146 times
RRB
by jps2000 on Sun Aug 25, 2019 2:09 am
That sounds like my observations:
viewtopic.php?f=57&t=155536
Try software version 0.11.0
Then probably it runs. Newer versions don´t work at the moment I think
Also burn the older bootloader. Not sure if there is backwards compatibility
jps2000
by jps2000 on Sat Aug 31, 2019 4:04 am
Arduino IDE 1.8.9 seems to work
jps2000
by RRB on Sat Aug 31, 2019 9:35 am
Thanks. Are you saying that IDE 1.8.9 works without having to fallback to an earlier board code? If not, while I can load an earlier board level, I do not know how to go back on the boot loader or which boot loader goes with which software level if that matters. I would like some help there unless 1.8.9 solves the entire problem.
RRB
by jps2000 on Sat Aug 31, 2019 10:07 am
In the arduino IDE just go to tools and click burn bootloader ( last entry)
this is always recommended because bootloader in a board may not be up to date even if you just have bought a new board.
So it is good practice to re- burn boot loader in case you take a fresh board or you have changed the version . This you do with the board manager.
The appropriate boot loader comes always when loading a new version. The bootloader version you also see in the tool menu.
jps2000
