Screw Inserts and tip for soldering iron
by wsquared58 on Fri Aug 23, 2019 5:36 pm
Is there a way to determine the hole size prior to using the brass inserts and special tip on a soldering iron such that melted plastic doesn't push up inside the insert as you push it in to hole? Just got my weatherproof box and it has a ton of places for inserts of various sizes but I know from messing around with a different box that if the pre-configured hole is too small the plastic wants to go in to the threads of the insert.
wsquared58
Re: Screw Inserts and tip for soldering iron
by franklin97355 on Fri Aug 23, 2019 8:22 pm
The insert is about 5.0mm. across the widest part and 4.3mm at the waist. I don't have one to measure but have a program I can use to get measurements from a picture.
franklin97355
