Using analog pin for interrupts? (Feather M4)
Re: Using analog pin for interrupts? (Feather M4)
by vattiat on Thu Sep 26, 2019 5:12 pm
Martin,
Since last, I noticed that using pin 13 would get me correct measurements, while all other GPIO pins would return incorrect measurements. Since pin 13 has a resistor and LED connected to ground in the Feather board, I tried duplicating this arrangement on other pins using and external 2.2kOhm resistor and LED. And it worked.
So maybe give that a try? Set the interrupt pin to INPUT (not INPUT_PULLUP) and then put a ~2kOhm resistor and LED in series from your GPIO pin to ground.
vattiat
by baekgaard on Fri Aug 07, 2020 12:16 pm
I know this is a bit old topic, but I went through the same challenge and finally realised that the external interrupts in the variants.h file were wrong...
I can see that I was not the only one having this issue, as coincidentally another person "NanoCodeBug" also found this and fixed it a few weeks ago.
Anyway, if you have the issue, change ArduinoCore-samd/variants/feather_m4/variant.cpp as follows:
  // 14..19 - Analog pins
  { PORTA,  2, PIO_ANALOG, PIN_ATTR_ANALOG, ADC_Channel0, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_2 },
  { PORTA,  5, PIO_ANALOG, PIN_ATTR_ANALOG, ADC_Channel5, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_5 },
  { PORTB,  8, PIO_ANALOG, (PIN_ATTR_ANALOG|PIN_ATTR_PWM_E), ADC_Channel2, TC4_CH0, TC4_CH0, EXTERNAL_INT_8 },
  { PORTB,  9, PIO_ANALOG, (PIN_ATTR_ANALOG|PIN_ATTR_PWM_E), ADC_Channel3, TC4_CH1, TC4_CH1, EXTERNAL_INT_9 },
- { PORTA,  4, PIO_ANALOG, (PIN_ATTR_ANALOG|PIN_ATTR_PWM_E), ADC_Channel4, TC0_CH0, TC0_CH0, EXTERNAL_INT_6 },
- { PORTA,  6, PIO_ANALOG, (PIN_ATTR_ANALOG|PIN_ATTR_PWM_E), ADC_Channel6, TC1_CH0, TC1_CH0, EXTERNAL_INT_10 },
+ { PORTA,  4, PIO_ANALOG, (PIN_ATTR_ANALOG|PIN_ATTR_PWM_E), ADC_Channel4, TC0_CH0, TC0_CH0, EXTERNAL_INT_4 },
+ { PORTA,  6, PIO_ANALOG, (PIN_ATTR_ANALOG|PIN_ATTR_PWM_E), ADC_Channel6, TC1_CH0, TC1_CH0, EXTERNAL_INT_6 },
So analog pins A4 (PA04, feather pin 18) ) and A5 (PA06, feather pin 19) should be associated with external interrupts 4 and 6, respectively (and not 6 and 10).
Hope this helps others too :-)
baekgaard
by Egholm on Sun Aug 09, 2020 7:07 am
Hi Per,
Thanks for the update...
Egholm
