I know this is a bit old topic, but I went through the same challenge and finally realised that the external interrupts in the variants.h file were wrong...
I can see that I was not the only one having this issue, as coincidentally another person "NanoCodeBug" also found this and fixed it a few weeks ago.
Anyway, if you have the issue, change ArduinoCore-samd/variants/feather_m4/variant.cpp as follows:
- Code: Select all | TOGGLE FULL SIZE
// 14..19 - Analog pins
{ PORTA, 2, PIO_ANALOG, PIN_ATTR_ANALOG, ADC_Channel0, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_2 },
{ PORTA, 5, PIO_ANALOG, PIN_ATTR_ANALOG, ADC_Channel5, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_5 },
{ PORTB, 8, PIO_ANALOG, (PIN_ATTR_ANALOG|PIN_ATTR_PWM_E), ADC_Channel2, TC4_CH0, TC4_CH0, EXTERNAL_INT_8 },
{ PORTB, 9, PIO_ANALOG, (PIN_ATTR_ANALOG|PIN_ATTR_PWM_E), ADC_Channel3, TC4_CH1, TC4_CH1, EXTERNAL_INT_9 },
- { PORTA, 4, PIO_ANALOG, (PIN_ATTR_ANALOG|PIN_ATTR_PWM_E), ADC_Channel4, TC0_CH0, TC0_CH0, EXTERNAL_INT_6 },
- { PORTA, 6, PIO_ANALOG, (PIN_ATTR_ANALOG|PIN_ATTR_PWM_E), ADC_Channel6, TC1_CH0, TC1_CH0, EXTERNAL_INT_10 },
+ { PORTA, 4, PIO_ANALOG, (PIN_ATTR_ANALOG|PIN_ATTR_PWM_E), ADC_Channel4, TC0_CH0, TC0_CH0, EXTERNAL_INT_4 },
+ { PORTA, 6, PIO_ANALOG, (PIN_ATTR_ANALOG|PIN_ATTR_PWM_E), ADC_Channel6, TC1_CH0, TC1_CH0, EXTERNAL_INT_6 },
So analog pins A4 (PA04, feather pin 18) ) and A5 (PA06, feather pin 19) should be associated with external interrupts 4 and 6, respectively (and not 6 and 10).
Hope this helps others too :-)
