USB DIY Slim Connector Shell - MicroB Plug #1826
- HNRAO
There is no wiring diagram with this product. Is it possible to get one?
- HNRAO
Re: USB DIY Slim Connector Shell - MicroB Plug #1826
Yes, but the one from Adafruit has pins on the top and bottom. Which number goes with which pin?
They're straight-through connections: the side with three contacts connects to pins 1, 3, and 5. The other side with two contacts connects to 2 and 4.
- HNRAO
Thanks. Adafruit should still put a technical drawing with the product to show what pin is what and from what direction you're looking to identify them.
- drunyan0824
Are the pins in order from left to right when I am looking at the tabs that I would solder the wires too?adafruit_support_mike wrote:They're straight-through connections: the side with three contacts connects to pins 1, 3, and 5. The other side with two contacts connects to 2 and 4.
