USB DIY Slim Connector Shell - MicroB Plug #1826
by HNRAO on Mon Oct 07, 2019 6:43 pm
There is no wiring diagram with this product. Is it possible to get one?
HNRAO
Re: USB DIY Slim Connector Shell - MicroB Plug #1826
by adafruit_support_mike on Tue Oct 08, 2019 12:40 am
They use the standard pinout for USB connectors:
https://en.wikipedia.org/wiki/USB_hardware#Pinouts
by HNRAO on Fri Nov 08, 2019 3:50 pm
Yes, but the one from Adafruit has pins on the top and bottom. Which number goes with which pin?
HNRAO
by adafruit_support_mike on Sat Nov 09, 2019 1:33 am
They're straight-through connections: the side with three contacts connects to pins 1, 3, and 5. The other side with two contacts connects to 2 and 4.
by HNRAO on Sat Nov 09, 2019 1:57 pm
Thanks. Adafruit should still put a technical drawing with the product to show what pin is what and from what direction you're looking to identify them.
HNRAO
by drunyan0824 on Wed May 05, 2021 9:40 am
adafruit_support_mike wrote:They're straight-through connections: the side with three contacts connects to pins 1, 3, and 5. The other side with two contacts connects to 2 and 4.
Are the pins in order from left to right when I am looking at the tabs that I would solder the wires too?
drunyan0824
by adafruit_support_mike on Thu May 06, 2021 1:35 am
Yes.
