STEMMA Soil Moisture Max Reading
Re: STEMMA Soil Moisture Max Reading
by tmeals on Sat May 09, 2020 11:51 pm
Come to think of it, the reading of 1015 on the moisture sensor has to relate to the temperature. Every time the temperature dips below around 79-80F, the moisture reading tends to spike to 1015 and not give an accurate reading.
tmeals
by eipe on Tue Jun 02, 2020 10:25 am
Hello there, new here.
I have the exact same problem. Output 1015 in dry soil and 1015 in wet soil. 300-400 in air.
adafruit_support_bill wrote:Re-flashing the firmware requires a JTAG programmer. But we can just replace the sensors.
Please contact support@adafruit.com with a link to this thread. And let us know how the new firmware works for you.
What do I have to do re-flash the firmware?
1. Buy a JTAG programmer (how do I know if it's compatible, or are they all?)
2. Then what..? Is it super-complicated? I have experience of using VS Code and PlatformIO for programming Arduino etc. but this seems like a "low level" thing
I can try with wrapping some plastics around the sensor. But else, should I just email my address / issue and then you'll send the replacement? I'm a teacher situated in Sweden
eipe
by adafruit_support_bill on Tue Jun 02, 2020 10:55 am
If your sensors were purchased recently, they already have the updated firmware. But we still see cases where the sensors become overloaded in some types of soil. Wrapping the sensor in a few layers of waterproof tape or heat-shrink decreases the sensitivity to where you can get better readings.
by cmcg on Sat Jun 20, 2020 12:32 pm
Regarding the volatility of the readings, I recently moved my setup to running of a lithuim ion battery pack and saw a huge decrease in the volatility:
Screenshot 2020-06-20 at 17.12.46.png (917.41 KiB) Viewed 46 times
Yellow is the raw read from the sensor, blue gives a normalised percentage.
We're running off a pizero, and have tried multiple mains powered adapters,including the official one with no luck. Different battery packs produce the same consiten values.
Running the sensor wrapped in heatshrink, powered via a battery pack gives us a pretty decent reading. Below we get a clear decline in moisture level, and its obvious when the plant was watered:
Screenshot 2020-06-20 at 17.20.12.png (348.63 KiB) Viewed 46 times
Any thoughts what would cause the difference between the powersupplies?
cmcg
by adafruit_support_bill on Sat Jun 20, 2020 12:40 pm
Most power supplies these days are switch-mode type supplies. These typically operate at fairly high frequencies and require filtering on the output to produce a steady DC voltage. Some have better filtering than others. Most have some residual switching noise on the output.
by tmeals on Sun Jun 21, 2020 2:07 pm
Regarding a fluctuating power supply -- would it be possible to put a capacitor in front of the STEMMA? If so, what size do you recommend?
tmeals
by adafruit_support_bill on Mon Jun 22, 2020 5:09 am
A capacitor might help. A common strategy is to pair a small ceramic cap with a larger electrolytic to get the best characteristics of each:
https://www.adafruit.com/product/753
https://www.adafruit.com/product/2195
