Led ON using WIFI and Two FEATHER HUZZAH W/ ESP8266 WIFI
by igeorge688 on Thu Jan 16, 2020 9:39 pm
I just bought TWO boards ASSEMBLED FEATHER HUZZAH W/ ESP8266 WIFI WITH STACKING HEADERS
I read the description and tried the example.
It works.
What i would like, is to get an example of interaction between the two boards using WIFI.
Lets say, each board has 3 Pushbuttons and 3 leds.
I would like some help to achieve:
Press B1 on board one and Led1 on board two is ON.
And vice versa, pressing let's say B2 on board 2 i can turn ON Led 2 on board 1.
At the moment i will be happy to start simple.
The leds, stay on as long as keep the button pressed, and when i release, led will turn OFF.
Also, for simplicity, each WIFI board is connected to the same SSID. Just inside of my house.
As i have two wireless routers in the house, I will put probably one board in one SSID and the other board on the other SSID.
Can somebody help me to start with ESP, and WIFI please ?
Once i have an example, i can read and play with it to develop more.
Thank you very much.
igeorge688
Re: Led ON using WIFI and Two FEATHER HUZZAH W/ ESP8266 WIFI
by brubell on Wed Jan 22, 2020 12:00 pm
Check out this guide: Remote control with the huzzah plus adafruit io
https://learn.adafruit.com/remote-contr ... dafruit-io
Note that this guide uses the 8266 Huzzah - you can easily substitute the Feather Huzzah w/8266 instead. Be sure to check the pinouts while building it.
The code in the guide above should work for this scenario, too.
brubell
by igeorge688 on Wed Jan 22, 2020 12:28 pm
Thank you very much Brubel,
I will read and test it .
You help me a lot by guiding me to a start.
Have a great day.
igeorge688
