Connecting Simple RF to Feather M0
Efronberg
Post by Efronberg »
I'd like to have a simple way to remotely signal my Feather M0 remotely.
I see that the Simple RF M4 uses 5V Technology whereas the Feather runs 3.3V
*IF* I always have a usb cable hooked to the feather M0, then the board has 5V available
on the USB 'pin' but I'm not sure whether the M0 GPIO's in input mode can handle the 4.7V tty signal.
Looking at the Data sheet has been unproductive, at least with an initial study I can't find
GPIO -- Vimax, but I also can't find a screwdriver when it right in front of my eyes.
Can the Feather M0 (atsamd21) support 4.7 volt to it's input ports?
BryonMiller
Re: Connecting Simple RF to Feather M0
Post by BryonMiller »
Here's the section you're looking for.
SAMD21 absolute Maximums
Says 5 volts (or anything higher than 3.6 volts) may smoke it.
Would you consider using voltage divider resistors to bring signal down to in-range?
Efronberg
Post by Efronberg »
Awesome.... that is exactly what I was looking for. I'll look into some type of voltage translation -- Voltage Divider, or some active circuitry.
thanks!
-- Eric
Efronberg
Post by Efronberg »
BTW found:
https://www.newark.com/pdfs/techarticle ... sBrchr.pdf
To show various tricks with 3-5v conversion solutions.
