Velosats
Re: Velosats
by animefruit on Sun Aug 16, 2020 2:38 pm
What do you mean by solder spatters?
animefruit
Re: Velosats
by animefruit on Sun Aug 16, 2020 2:43 pm
So you say I should remove the solder spatters. How do I do that? Do you mean I need to desolder all my joints on the front and have to resolder them?
animefruit
Re: Velosats
by adafruit_support_bill on Sun Aug 16, 2020 2:52 pm
Remove these blobs of solder:
And fix these so the solder flows onto the solder pads:
Re: Velosats
by animefruit on Sun Aug 16, 2020 2:56 pm
Ok. Thankyou. I will do that.
animefruit
Re: Velosats
by animefruit on Tue Aug 18, 2020 6:04 pm
So I tried to put those solder joints on to the pad and I still do not see characters on the lcd. Does this photo of my solder joints look good now? The adafruit site for assembling an lcd that you gave me says that if you can’t see any characters on the lcd than you should adjust the potentiometer. Is there some way I could adjust the contrast without a potentiometer?
animefruit
Re: Velosats
by adafruit_support_bill on Wed Aug 19, 2020 6:56 am
There is a potentiometer on the backpack board. It is the little metal part next to where it says "Contrast".
You can use a small screwdriver to turn it. Be very gentle when turning and do not force it. Turning past the stops will damage the potentiometer.
Re: Velosats
by animefruit on Thu Aug 27, 2020 10:17 pm
Ok. I did that and it worked when I used the HelloWorld 12c sketch. But it seems to not work with my other code. Can you tell me what I am doing wrong with my other code? Here is my other code:
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_LIS3DH.h>
#include <Adafruit_Sensor.h>
#include <Servo.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3,POSITIVE);
// Used for software SPI
#define LIS3DH_CLK 13
#define LIS3DH_MISO 12
#define LIS3DH_MOSI 11
// Used for hardware & software SPI
#define LIS3DH_CS 10
// software SPI
//Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS, LIS3DH_MOSI, LIS3DH_MISO, LIS3DH_CLK);
// hardware SPI
//Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS);
// I2C
Adafruit_LIS3DH lis_A = Adafruit_LIS3DH();
Adafruit_LIS3DH lis_B = Adafruit_LIS3DH();
Servo myservo;
int health=5000;
int reading;
int reading2;
int pos;
void setup(void) {
  lcd.begin (16 ,2);
  lcd.clear();
  Serial.begin(9600);
   myservo.attach(9); //servo at digital pin 9
 myservo.write(0); //initial point for servo
  while (!Serial) delay(10);     // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("LIS3DH test!");
 if (! lis_A.begin(0x18)) {   // change this to 0x19 for alternative i2c address
    Serial.println("Couldnt start A");
   while (1) yield();
  if (! lis_B.begin(0x19)) {   // change this to 0x19 for alternative i2c address
    Serial.println("Couldnt start B");
    while (1) yield();
  Serial.println("LIS3DH found!");
   lis_A.setRange(LIS3DH_RANGE_4_G);   // 2, 4, 8 or 16 G!
   lis_B.setRange(LIS3DH_RANGE_4_G);
  //Serial.print("Range = "); Serial.print(2 << lis_A.getRange());
  Serial.print("Range = "); Serial.print(2 << lis_B.getRange());
  Serial.println("G");
  // lis.setDataRate(LIS3DH_DATARATE_50_HZ);
 Serial.print("Data rate set to: ");
  switch (lis_A.getDataRate()) {
    case LIS3DH_DATARATE_1_HZ: Serial.println("1 Hz"); break;
    case LIS3DH_DATARATE_10_HZ: Serial.println("10 Hz"); break;
    case LIS3DH_DATARATE_25_HZ: Serial.println("25 Hz"); break;
    case LIS3DH_DATARATE_50_HZ: Serial.println("50 Hz"); break;
    case LIS3DH_DATARATE_100_HZ: Serial.println("100 Hz"); break;
    case LIS3DH_DATARATE_200_HZ: Serial.println("200 Hz"); break;
    case LIS3DH_DATARATE_400_HZ: Serial.println("400 Hz"); break;
    case LIS3DH_DATARATE_POWERDOWN: Serial.println("Powered Down"); break;
    case LIS3DH_DATARATE_LOWPOWER_5KHZ: Serial.println("5 Khz Low Power"); break;
    case LIS3DH_DATARATE_LOWPOWER_1K6HZ: Serial.println("16 Khz Low Power"); break;
    switch (lis_B.getDataRate()) {
  lcd.setCursor(0, 1);
  do
   myservo.detach();
  reading = lis_A.y;
  reading2 = lis_B.y;
if (reading < -4000 ){
  reading=0;
 if(reading > -4000){
  Serial.println(reading);
  lcd.println(reading);
if (reading2 < -4000 ){
  reading2 =0;
 if(reading2 > -4000){
  Serial.println(reading2);
  lcd.println(reading2);
  lis_A.read();      // get X Y and Z data at once
  // Then print out the raw data
  //Serial.print("X:  "); Serial.print(lis.x);
Serial.print("  \tY:  ");Serial.print(lis_A.y);
  //Serial.print("  \tZ:  "); Serial.print(lis.z);
 lis_B.read();      // get X Y and Z data at once
  //Serial.print("X:  "); Serial.print(lis_B.x);
Serial.print("  \tY:  ");Serial.print(lis_B.y);
  //Serial.print("  \tZ:  "); Serial.print(lis_B.z);
  /* Or....get a new sensor event, normalized */
  sensors_event_t event;
  //lis_A.getEvent(&event);
  lis_B.getEvent(&event);
  /* Display the results (acceleration is measured in m/s^2) */
  //Serial.print("\t\tX: "); Serial.print(event.acceleration.x);
  //Serial.print(" \tY: "); Serial.print(event.acceleration.y);
  //Serial.print(" \tZ: "); Serial.print(event.acceleration.z);
  //Serial.println(" m/s^2 ");
//float totalAcceleration = sqrt((event.acceleration.x * event.acceleration.x) + (event.acceleration.y * event.acceleration.y) + (event.acceleration.z * event.acceleration.z));
  //Serial.println();
    //reading = analogRead(A4 & A5);
    Serial.print("Sensor Value=");
    //reading - 100;
    health=health +reading +reading2;
    //health=health-reading2;
    Serial.println(health);
    lcd.println(health);
   // if ( health< 10000){
  //delay(600);
  delay(600);
} while(health>1);
/*myservo.attach(9);
//myservo2.attach(11);
  // attaches the servo on pin 9 to the servo object
  delay(15);
  myservo.write(1);
 // myservo2.write(1);
  // sets the servo position according to the scaled value
  delay(1000);
  // waits for it to get to the position
  myservo.detach();
 // myservo2.detach();
  delay(6000);//how long it pauses
  myservo.attach(9);
  delay(15);
  myservo.write(179);
  //myservo2.write(179);
  delay(1000); // waits for it to get to the position
  myservo.detach();
  //myservo2.detach();
  delay(1000);
  health=5000;
animefruit
Re: Velosats
by adafruit_support_bill on Fri Aug 28, 2020 6:04 am
You are declaring your display to use standard wiring via pins.
You need to declare it to use address #0 on i2c as it is done in HelloWorld_i2c:
LiquidCrystal_I2C lcd(0);
Re: Velosats
by animefruit on Fri Aug 28, 2020 9:54 pm
I did that, but it still doesn't work on my lcd. Is there anything else in my code I need to change. Here is my changed code:
#include <Wire.h>
#include <SPI.h>
#include <Servo.h>
//LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3,POSITIVE);
// software SPI
// hardware SPI
// I2C
Servo myservo;
int health=5000;
int reading;
int reading2;
int pos;
void setup(void) {
  lcd.begin (16 ,2);
  lcd.clear();
  Serial.begin(9600);
   while (1) yield();
    while (1) yield();
  //lcd.setCursor(0, 1);
  do
   myservo.detach();
  reading = lis_A.y;
  reading2 = lis_B.y;
  reading=0;
  reading2 =0;
  //Serial.println();
    //reading - 100;
  //delay(600);
  delay(600);
} while(health>1);
  delay(15);
  myservo.write(1);
  delay(1000);
  myservo.detach();
  myservo.attach(9);
  delay(15);
  myservo.write(179);
  myservo.detach();
  delay(1000);
  health=5000;
animefruit
Re: Velosats
by adafruit_support_bill on Sat Aug 29, 2020 6:08 am
What output do you see on your serial monitor?
Re: Velosats
by animefruit on Sun Aug 30, 2020 10:38 pm
Its printing off the accelrometer values like it should.
animefruit
Re: Velosats
by adafruit_support_bill on Mon Aug 31, 2020 7:12 am
Is the backlight on? You may need to add a command to turn it on in your setup()
lcd.setBacklight(HIGH);
Re: Velosats
by animefruit on Fri Sep 04, 2020 9:11 pm
Where in my code do I put this? I put it somewhere in my code and it still doesn't work. Here is my code with that code you sent me :
#include <Wire.h>
#include <SPI.h>
#include <Servo.h>
// software SPI
// hardware SPI
// I2C
Servo myservo;
int health=5000;
int reading;
int reading2;
int pos;
void setup(void) {
lcd.setBacklight(HIGH);// ada
  lcd.begin (16 ,2);
  lcd.clear();
  Serial.begin(9600);
   while (1) yield();
    while (1) yield();
  do
   myservo.detach();
  reading = lis_A.y;
  reading2 = lis_B.y;
  reading=0;
  reading2 =0;
  //Serial.println();
    //reading - 100;
  //delay(600);
  delay(600);
} while(health>1);
  delay(15);
  myservo.write(1);
  delay(1000);
  myservo.detach();
  myservo.attach(9);
  delay(15);
  myservo.write(179);
  myservo.detach();
  delay(1000);
  health=5000;
animefruit
Re: Velosats
by adafruit_support_bill on Sat Sep 05, 2020 6:05 am
  lcd.begin (16 ,2);
  lcd.clear();
You are calling lcd.setBacklight before you call lcd.begin. You can't send other commands to the board until after you call begin().
Re: Velosats
by animefruit on Sat Sep 05, 2020 2:19 pm
It is still not working, and I put the code after the "lcd.begin". Is there anything else I am missing to make this lcd not work for this code? Here is my code where I put the code you told me to use after begin:
#include <Wire.h>
#include <SPI.h>
#include <Servo.h>
// software SPI
// hardware SPI
// I2C
Servo myservo;
int health=5000;
int reading;
int reading2;
int pos;
void setup(void) {
  lcd.begin (16 ,2);
  lcd.clear();
  Serial.begin(9600);
   while (1) yield();
    while (1) yield();
  do
   myservo.detach();
  reading = lis_A.y;
  reading2 = lis_B.y;
  reading=0;
  reading2 =0;
  //Serial.println();
    //reading - 100;
  //delay(600);
  delay(600);
} while(health>1);
  delay(15);
  myservo.write(1);
  delay(1000);
  myservo.detach();
  myservo.attach(9);
  delay(15);
  myservo.write(179);
  myservo.detach();
  delay(1000);
  health=5000;
animefruit
