Velosats
Re: Velosats
by adafruit_support_bill on Tue Mar 03, 2020 9:28 pm
I don't have any idea what range of output you are getting from your velostat sensor. You need to test it to see what values you get with a projectile impact and filter everything else.
Re: Velosats
by animefruit on Tue Mar 03, 2020 9:50 pm
Right now is like 282 since I readjusted it.And than when I press it , it goes up and than goes down to 279 and than back to 281.So I don't think this is very accurate at all.I think right now I want to know if that accelrometer you were talking about is arduino connectable and is compatible for bread board pins.
animefruit
Re: Velosats
by adafruit_support_bill on Wed Mar 04, 2020 6:40 am
All of our accelerometers are compatible with Arduinos. And there are links to the tutorials on the product page. Here is the tutorial for the LIS3DH.
https://learn.adafruit.com/adafruit-lis ... r-breakout
Re: Velosats
by animefruit on Sat Mar 07, 2020 9:57 pm
This is Neal.What wires do I use to solder the arduino to my other device?What gauge and type?
animefruit
Re: Velosats
by adafruit_support_bill on Sun Mar 08, 2020 8:01 am
Since this is on a wearable device, you will want something that is flexible. So I would use a small gauge stranded wire. Something in the 24 to 30 AWG range.
Re: Velosats
by animefruit on Mon Mar 09, 2020 9:54 am
Sounds good I will try that.
animefruit
Re: Velosats
by animefruit on Wed Mar 25, 2020 11:37 am
This is Neal.What should I use to solder my Arduino.Is there something like the Arduino I can use to solder up?I am currently using the Arduino Uno.
animefruit
Re: Velosats
by adafruit_support_bill on Wed Mar 25, 2020 12:43 pm
The Metro Mini 328 is an Arduino UNO compatible board in a nice small size: https://www.adafruit.com/product/2590
Re: Velosats
by animefruit on Wed Mar 25, 2020 1:32 pm
I might use that.Thankyou.
animefruit
Re: Velosats
by animefruit on Wed Mar 25, 2020 1:33 pm
The only problem though ,is that I can’t find a usb cable for it.Do you offer them on your website?
animefruit
Re: Velosats
by adafruit_support_bill on Wed Mar 25, 2020 1:37 pm
It uses a standard USB Micro cable like this: https://www.adafruit.com/product/2185
Re: Velosats
by animefruit on Wed Mar 25, 2020 1:40 pm
Ok.I might use that.Thankyou.
animefruit
Re: Velosats
by animefruit on Wed Mar 25, 2020 2:13 pm
I also want to connect battery to it.So I am thinking of using one of those battery cases with wires so I can solder them.This one I am looking at is like the first thing that shows up when I search "9v battery case" on Amazon.Here is the link to what I am looking at.
https://www.amazon.com/LAMPVPATH-Pack-B ... ics&sr=1-3
Will I be able to solder the wires from the battery case, if not what is another way how to do this?
animefruit
Re: Velosats
by adafruit_support_bill on Wed Mar 25, 2020 2:52 pm
9v is way more than you need. A 4xAA is a better choice: https://www.adafruit.com/product/830
An even better option would be a Feather 32U4 : https://www.adafruit.com/product/2771
This will run from a 3.7V LiPo and has a built-in charger.
Re: Velosats
by animefruit on Wed Mar 25, 2020 3:06 pm
Well I am connecting 1 servo motor,1 lcd, and like 50 sensors to it, so I think I need a good amount of voltage.So will that chargeable feather support enough voltage for that?And are the wires from a battery case solderable?
animefruit
