Substitutes for out-of-stock items?
Re: Substitutes for out-of-stock items?
by Ekoch on Fri May 22, 2020 5:35 pm
Hi! I’m going to order the PID 1713 mic and 3870 on off switch for this project. Without a mic, what is the sound source for this and how will I connect the mic when it comes?
From the newbie!
Ekoch
by adafruit_support_bill on Sat May 23, 2020 6:15 am
You can use most any sound source - as long as it has a line-level or headphone output jack. Many people use MP3 players or smart-phones.
by Ekoch on Sat May 23, 2020 11:36 am
I want to use it to pick up sounds in a room, not amplify sounds from an electronic source. Is there a way to do that?
Ekoch
by adafruit_support_bill on Sat May 23, 2020 11:47 am
You will need a microphone & microphone amp. If you are using something like this one: https://www.adafruit.com/product/1713
You can wire directly from the microphone amplifier board to the power amplifier board.
Connect GND to R- and L-.
Connect OUT tot R+ and L+
by Ekoch on Sat May 23, 2020 12:06 pm
Thank you! Can I remove the headphone jack since I won’t be using it?
Ekoch
by adafruit_support_bill on Sat May 23, 2020 12:07 pm
Yes. You can remove the jack.
by Ekoch on Sat May 23, 2020 1:24 pm
Thank you!
Ekoch
by Ekoch on Fri Jun 12, 2020 5:25 pm
I’m about to solder the mic onto the power amplifier board and wondered if I jump the R- and L-pins together so they both connect to the ground? Do I do the same for the R+ and L+ that connects to the OUT?
Ekoch
by Ekoch on Fri Jun 12, 2020 7:12 pm
I assembled the pieces for the bone conductor and jumped the negatives together and soldered the positives together for the mic. Tried turning it on and nothing happened when I turned it on and talked into the mic. I tried switching the on/off switch both ways. Help!
Back side
Front side
Ekoch
by adafruit_support_bill on Fri Jun 12, 2020 8:53 pm
Yes. Connect GND to R- and L-.
by Ekoch on Fri Jun 12, 2020 10:17 pm
Why isn’t it working?
Ekoch
by adafruit_support_bill on Sat Jun 13, 2020 5:52 am
You have no power to the microphone. You need to connect power to the VDD pin.
https://learn.adafruit.com/adafruit-agc ... g-and-test
It also looks like a lot of cold joints. And some joints do not appear to be soldered at all.
https://learn.adafruit.com/adafruit-gui ... n-problems
