Hi, I have a problem with my Amg 8833 thermal camera sensor.
I am using the Arduino UNO for the connection And after followed all the steps on the Adafruit website for the connection and example code.
The Serial Monitor shows the value is -127.94. It is not showing as a room temp.
please help.
Amg8833 Thermal camera not working
- PromiseGentle
- Attachments
- this is the monitor showing
- THERMAL CAMERA ERROR.PNG (330.74 KiB) Viewed 274 times
- This is my connection
- IMG_3639.jpeg (992.28 KiB) Viewed 274 times
- adafruit_support_carter
Re: Amg8833 Thermal camera not working
Are the header pins soldered on the breakout?
- PromiseGentle
not soldered, just simply plug in.
Unfortunately, that won't create a reliable enough connection for it to work.
https://learn.adafruit.com/adafruit-gui ... aq-3028525
You'll need to solder on the headers.
- PromiseGentle
ok. I see. thank you
