Can any one of IMUs measure velocity?
by eikish on Mon May 18, 2020 5:26 pm
Can't find any reliable info on measuring velocity (like in a straight line, not spin velocity) with Adafruit IMU boards. I know accelerometers alone are not great to measure velocity because you would need to pull the acceleration info often (assuming you start with velocity=0) and calculate V continuously with the compounding error rate.
I want to strap an IMU on the back of another sensor to "label" the velocity along with the other sensors data together with timestamps. I'll be moving/shaking the package manually or with some contraption back and forth along a mostly linear path while facing the same direction and I'm missing the velocity in the direction the package is moving (starting from 0).
eikish
Re: Can any one of IMUs measure velocity?
by adafruit_support_bill on Mon May 18, 2020 5:55 pm
I don't know of any hobbyist grade IMUs that will calculate velocity for you. You generally need to integrate the acceleration over time in order to get velocity.
by jps2000 on Tue May 19, 2020 1:06 am
First of all you need to replace the word measure by estimate :-)
Integrating linear acceleration does the job but integration over time cumulates offset errors quickly.
You need to take linacc because you have to cancel out gravity. Also high pass filtering ( differentiation) may do this. The latter is only approipriate for "fast" movements.
In case of planar and horizontal movements you may just ignore the z (vertical) component.
Having sinusoidal movements you can calculate velocity from the peak acc value in case the frequency and amplitude is known.
jps2000
by bludin on Tue Jun 02, 2020 3:28 am
Velocity is always relative to something. If you have a reference, you may use a sensor to measure the distance (e.g. via ToF, VL6180X) and calculate the velocity from that.
bludin
