Help with MAX31865 programming
by lefs on Wed May 20, 2020 6:52 pm
Greetings
I have an Adafruit MAX31865 board and a STM32F750 board. I have tried to get the Maxim chip to work without succes. Can you tell what to write there. Or any other tricks to try.
Now I get only FFh from the chip. I have tried various ways to set up SPI bus and STM software and FFh is the best I can get.
Maxim chip uses SPI bus and atleast CPU sends something to chip. I can see it on scope.
This is the setup data
txBuffer[0] = 0x80; //address
txBuffer[1]=0xC3; //data
txBuffer[2] = 0x83;
txBuffer[3]=0xff;
txBuffer[4] = 0x84;
txBuffer[5]=0xff;
txBuffer[6] = 0x85;
txBuffer[7]=0x00;
txBuffer[8] = 0x86;
txBuffer[9]=0x00;
HAL_SPI_TransmitReceive (&hspi1, txBuffer, rxBuffer, 8, 1000);
RX buffer is full of FFh after this.
Regards
Leif M
lefs
Re: Help with MAX31865 programming
by lefs on Wed May 20, 2020 7:38 pm
There is definitely is something wrong in the setup. The Bias voltage 2V is missing from the Reference resistor.
lefs
by lefs on Thu Jul 02, 2020 2:26 pm
This is late but I want to report to all you that Adafruit Max31865 work and work with STM32H750 board, too.
I had to read the datasheet very well. Last thing to fix was a missing lead and get my formulas correct. In this version, I drive GPIO pin directly.
Like this:
CS low
Write 0x80 and 0x83
CS up.
CS low
Write 0x80 and 0xc3
CS up
repeat
CS down
you can read temperature data now
cs up
i used small delay between before I made cs active.
My variable names are in Finnish, so they wont tell you a lot. I'll put only a fragment here of my clumsy C code.
char msg[40];
int lamp1,lamp2;
double lampf, lampf2;
 lamp1=rxBuffer[2]*256;  //MSB
 lamp1=lamp1+(rxBuffer[3]);  //LSB
 lamp1=lamp1/2; //0bitti can be deleted, that is, an error indicator
 lampf=lamp1;
 lampf2=lamp1;
 lampf=lampf*430/32768;  //Rrtd page 19
strcpy(msg, "");
sprintf(msg ,"PT100 Resistanssi %f4.0 \n\r",lampf);
HAL_UART_Transmit(&huart1, (uint8_t*)msg, strlen(msg), 1000);
strcpy(msg, "");
lampf=((lampf/100.0)-1.0)/(0.003851);
sprintf(msg ,"lampotila Celsius %f4.0 \n\r",lampf);
strcpy(msg, "");
HAL_GPIO_WritePin(GPIOE,GPIO_PIN_3,GPIO_PIN_SET);   //cs 1
HAL_GPIO_WritePin(GPIOA,GPIO_PIN_5,GPIO_PIN_SET);//clk 1
HAL_Delay(5);
lefs
