LED ON/OFF Illuminated Triangle pushbutton
by Ac429hill on Thu May 28, 2020 5:19 pm
We purchased the on/off illuminated triangle 1960’s button. We need to know which plug is the output to the device and which is to the battery. I couldn’t find a diagram explaining the tech info. Any help would be appreciated.
Thank you
Ac429hill
Re: LED ON/OFF Illuminated Triangle pushbutton
by adafruit_support_carter on Fri May 29, 2020 12:13 pm
There should be + and - symbols to indicate the LED connections. This photo may also help, which show only the LED being powered:
https://cdn-shop.adafruit.com/970x728/4190-00.jpg
There are two contacts for the button and two contacts for the LED, one marked + and one -. The forward voltage of the LED is about 2.2V so connect a 220 to 1000 ohm resistor in series just as you would with any other LED to your 3V or higher power supply.
