i have a problem with TWO MAX9744 on my Raspberry (3B):
I have connected both MAX with the needed pins 1:1 to my RPi. Means also both MAX are connected each other (except the Audio-Minus wire).
As long i dont give an audio input, my
i2cdetect -y 1
shows me both MAX on address 4a and 4b (everytime i call i2cdetect) and i can control the volume via i2c without any problems.
Next step, i connect a audio source (only plus wire). Everything works as described above, except that the sound is scratchy of course, because i only connected the plus line from the audio source.
Next step: I connect the minus wire from the audio source, too.
After the last step my i2c becomes unstable, means sometimes i see both MAX (4a + 4b), sometimes only one of them:
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: 10 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- 41 -- -- -- -- -- -- -- -- -- 4b -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: 70 -- -- -- -- -- -- --
pi@pyCAR:~ $ i2cdetect -y 1
40: -- 41 -- -- -- -- -- -- -- -- 4a 4b -- -- -- --
I should say that my Audio-Source is a Google Voice HAT (in Stereo).
Kind Regards
Thomas
