Auto run no longer works?
by Orendacl on Wed Jun 10, 2020 10:44 am
Hello.
When I first installed my Adafruit eyes software I made one cruicial mistake; I selected TFT for my 240x240 displays. The resultant was the eyes program would run but I only saw lines on my two displays.
Realizing my error I went back and reinstalled the software this time choosing option 3 for the proper display type.
The issue now, after everything powers back on is the eyes program NO LONGER Auto Runs.
I mean, it does not start up.
I see the surreal mountain road on my monitor and the same thing on my displays.
What I would like is to use this as a Holloween prop and I simply need the eyes to run everytime it is powered on. When it turns off and powers back up I simply want they eyes running without my user manipulation.
Can someone tell me what might have been corrupted? Or what code text to add?
Again, it was auto running before....
Orendacl
Re: Auto run no longer works?
by adafruit_support_carter on Wed Jun 10, 2020 11:28 am
Were you following this installation process?
https://learn.adafruit.com/animated-sna ... stallation
by Orendacl on Wed Jun 10, 2020 11:44 am
Yes, that is in fact the procedure I was following....
Now, as said I incorrectly selected TFT (option 2) when I should have used option 3 for my 240x240 adafruit TFT displays.
It caused white lines on my displays.
I elected to restart the Raspberry pressing SHIFT to reinstall the software and do it over.
Upon doing so my system starts up to the mountain road scene and that is displayed on my adfruit eyes.
There has to be a simple solution to this.
Orendacl
by adafruit_support_carter on Wed Jun 10, 2020 12:04 pm
Look in your /etc/rc.local file for a line that starts with:
/boot/Pi_Eyes/fbx2
and paste the complete line here.
by Orendacl on Wed Jun 10, 2020 12:32 pm
Hopefully I am at the right area:
I went to /etc
Then I expanded RC0 through RC6 and RCs.
All of the folders say <No subdolders>
Am I in the wrong area?
Orendacl
by adafruit_support_carter on Wed Jun 10, 2020 12:37 pm
rc.local is a file in the /etc folder.
This may be an easier way to do this, try running this command:
cat /etc/rc.local | grep Pi_Eyes
by Orendacl on Wed Jun 10, 2020 12:53 pm
After attempting the code I see:
/boot/Pi_Eyes/fbx2 -i &
cd /boot/Pi_Eyes; python3 eyes.py -- radius 240 &
Orendacl
by adafruit_support_carter on Wed Jun 10, 2020 1:00 pm
That seems OK. Try running those two lines interactively and see if the eyes shows up.
by Orendacl on Wed Jun 10, 2020 1:39 pm
What do you mean by interactively?
If meaning type this code:
cat /etc/rc.local
Then:
grep Pi_Eyes
The result is no change.
The eyes are broadcasting the desktop seen (a desert highway).
Orendacl
by adafruit_support_carter on Wed Jun 10, 2020 1:45 pm
Run this command:
then run this command:
by Orendacl on Wed Jun 10, 2020 1:52 pm
If you were meaning type each line:
I then get:
[2] 4401
[1] Exit 127. / fbx2 -i
Cant open dev men try sudo
Next line code:
cd /boot/Pi_Eyes; python3 eyes.py. -- radius 240 &
I get:
[3] 4427
[2] Exit 1. /boot/Pi_Eyes/fbx2 -i. (wd....
(wd now: /boot/Pi_eyes)
File "eyes.py", line 9, in <module>
Import pi3d
Importerror: no module named pi3d
Orendacl
by adafruit_support_carter on Wed Jun 10, 2020 2:09 pm
Yep. That was the idea. Hmmm, OK, let's try again but this time with sudo:
sudo /boot/Pi_Eyes/fbx2 -i &
and then:
cd /boot/Pi_Eyes; sudo python3 eyes.py -- radius 240 &
by Orendacl on Wed Jun 10, 2020 3:10 pm
Result error:
File "eyes.py" line 9 in <module>
Import pi3d
Importerror: No module named 'pi3d'
Orendacl
by adafruit_support_carter on Wed Jun 10, 2020 3:56 pm
It's acting like it's missing a module that should have been installed by the script. Let's double check that.
You can list the installed modules with:
pip3 list
but since the install is done with sudo, you'll want to also check the same way, so run:
sudo pip3 list
and check if pi3d is in the list. If the list is too long, you can filter it with:
sudo pip3 list | grep pi3d
by Orendacl on Wed Jun 10, 2020 5:04 pm
When executing the list commands I do not see pi3d.
Orendacl
